corvette filter
Old Jul 17, 2014 | 05:37 PM
kodyowenby10's Avatar
Default corvette filter
So which way is it everything i look at shows different. Is the 5/16 the inlet from pump and the 3/8 is the return to the tank? That is how my microguard 33737 filter is marked also.
post #13
https://ls1tech.com/forums/conversio...ilter-reg.html
this says the other way
https://ls1tech.com/forums/conversio...-question.html
Old Jul 17, 2014 | 06:22 PM
67Skylark's Avatar
Hard Line = Inlet
Rubber Line = Return
Steel braided = outlet
Got about 400 miles on it so far.
Old Jul 17, 2014 | 06:35 PM
lsxRanger94's Avatar
I am looking at the filter in question right now in my hand. Mine is not marked, But 67skylark is correct with the mounting locations(inlets and outlet). If yours does not have the 5/16 center return and 3/8 side feed with a 3/8 center outlet, you may have the wrong filter in the box. Which case may not be the 55psi regulator that you need.
Old Jul 17, 2014 | 06:50 PM
Here is what I got it looks the same I tried blow gun in the 5/16 port and it will not do anything with 160psi going to it but the 3/8 flows straight threw
Old Jul 17, 2014 | 06:58 PM
Since yours is new like the one I have, but without the markings. try this. You can blow thought the inlet easily. You can not blow through the return. This filter allows pressure to build all the way to the injectors first and then the excess is bled off through the return to the tank.
Old Jul 17, 2014 | 10:21 PM
I will try blocking off the feed to the injectors tomorrow. I'm not sure why it's labeled anyways cause a factory corvette has different sized lines so u should not be able to cross them anyways.
ls1nova71's Avatar
I think that sticker should be on the other side of the filter. The 3/8 is the feed line in, and the 5/16 is the return. The female end is the feed line to the rail.
Old Jul 17, 2014 | 11:03 PM
I didn't thank u would have more feed out than in but even if the sticker was upside down the arrow for flow like most filters would have been backwards
Old Jul 17, 2014 | 11:09 PM
amr84ss's Avatar
The return line on this filter is also the pressure regulator, just like lsxranger said. You will not get anything through it until it exceeds the pressure it it rated to. I think that rating is 50 psi, I might be lieing though.
Old Jul 17, 2014 | 11:10 PM
ls1nova71's Avatar
I didn't thank u would have more feed out than in but even if the sticker was upside down the arrow for flow like most filters would have would be backwards
The sticker isn't upside down, just on the wrong side. In your picture, if the sticker was in the same direction, just on the other side (where you couldn't see it, next to your hand in the pic) it would be labeled correctly.
Old Jul 17, 2014 | 11:12 PM
ls1nova71's Avatar
The pressure rating is 58psi.
Old Jul 17, 2014 | 11:15 PM
amr84ss's Avatar
I thought that after I posted that last post.
Here is my set up. Top is fuel in from pump, bottom is return to tank.
