A/C request Blue/Green connector ECU
Old 09-05-2018, 07:01 PM
  #101
xEtherealx's Avatar
I think most of the confusion arose from the desire to eliminate the pin 80 pressure sensor from the system (notice I don't have it in my diagram above). If I understand correctly autocomman, you're saying that you have to have this sensor intact to use the truck ECM/flash? Or is it just necessary if you want certain features?
Old 11-02-2018, 11:15 AM
  #102
xEtherealx's Avatar
Anyone?
Old 12-29-2018, 10:53 AM
  #103
Poor not Lazy's Avatar
Originally Posted by ls1nova71
Ok, so I'm back at this again..... What I have now is a 2004 Silverado 6.0, and rewired the A/C back to the way it was originally in the '04 with the three wire pressure sensor. I added the wire for the 12v A/C request and just want to know what exactly to set the parameters to in the tune. I know it was serial originally, and need to change it to analog, but is it "analog cycling"? Basically all I want to do is add the 12v request to an '04 Silverado.
ls1nova71 Were you able to figure this out? I don't think my PCM (12586242) has the drivers for the 12v request so I think i would have to add the A/C module for the serial input.
Old 05-15-2019, 01:28 PM
  #104
squeak12's Avatar
So I've read this entire thread due to the problem I currently have. I have an 04 suburban 5.3 and 4l60e swapped into a 91 suburban with vintage air. I'm using the factory 3 wire pressure sensor, everything is wired right and I'm getting the 12v ac request at green 17 verified with a test light. I can use hptuners vcm scanner to command the AC compressor on through the pcm, when I do the AC blows cold and the cooling fans come on when the pressure threshold is reached. My PCM is service number 12586242. I've come to understand that it is simply not capable of accepting the 12v request. Here's my dilemma: I have HP tuners and don't want to waste credits trying to find a PCM that will control my fans and AC while being DBW. Can anyone tell me a PCM service number that they know will accomplish this?
Old 05-15-2019, 02:06 PM
  #105
Received 3,153 Likes on 2,460 Posts
You might try contacting LSX Power Tuning. Not positive they would know, but it's worth a shot. They are of a lot of help on this forum.
Old 01-17-2021, 07:07 PM
  #106
rocketmench's Avatar
Hi all, reviving an old thread here. I can confirm that P59 pcm's (2003+ blue/green pcm's) that do not have the IAC mosfets and circuitry are missing the circuitry to read the 12 V AC request signal. This was determined by opening up two pcm's, one with the IAC controllers (service no 12576106) and one without the IAC controllers (service no. 12586242), and tracing out the circuit at C2 pin 17 on each. I found that the non-IAC pcm is missing a couple resistors and capacitors. Should be possible to enable 12 V AC request simply by soldering these components in. I am attaching a pdf file with the details. PM me with any questions.
File Type: pdf
The following users liked this post:
Dcon (07-19-2021)
Old 08-30-2021, 06:02 PM
  #107
Skylerm09's Avatar
Have you actually solder these in place to see if it work? I messed around all day trying different thing to get mine to work and come across this, I have already order the resistor and capacitor to try, but have you gotten it to work?
Old 08-30-2021, 06:49 PM
  #108
Who are you asking?
Old 08-30-2021, 07:36 PM
  #109
Skylerm09- yes, I did solder these elements (2 resistors and a capacitor) into the motherboard, and the changes worked. I was able to show this with a bench-top experiment (see document attached). Providing 12 volts to C2 17 in the PCM resulted in the voltage at C2 43 going low, which is an indication that the PCM is trying to command the AC compressor to come on.
Note that to get this to work on the benchtop, you have to simulate the crank and cam signals, which I did with a arduino and the ardustim c-code software found online which I modified for my own use.
I was also able to get the 2 fan controls to cycle on and off by simulating the engine coolant temperatures with a potentiometer.
So all these functions were working in a PCM that did not originally work.
The following 3 users liked this post by rocketmench:
ChipsByAl (09-06-2022), Skylerm09 (08-30-2021), V8 Cowboy (05-27-2023)
Old 08-30-2021, 08:12 PM
  #110
Skylerm09's Avatar
Can you give me exact on the capacitor? I order 100,10, 3. kOhm resistor I didn’t really understand what you were saying, I’m no professional or even a novice at this but I seen you picture and I’m good with a iron. So I wanna give it a shot before I spend 100$ on credits and 50 on a pcm.
Old 08-30-2021, 08:15 PM
  #111
Skylerm09's Avatar
I just looked at your attachment and it’s step by step, thank you so much
Old 08-30-2021, 08:18 PM
  #112
Skylerm09's Avatar
I can’t pm you is there anyway I can?
Old 08-30-2021, 09:00 PM
  #113
I just sent you a pm, check your messages.
Old 08-30-2021, 09:11 PM
  #114
Skylerm09's Avatar
I just made this account, but it still saying I don’t have the “privileges” to message
Old 08-30-2021, 09:12 PM
  #115
Skylerm09's Avatar
Oh, I have to be a member for 30 days or make 10post.
Old 08-30-2021, 09:31 PM
  #116
Skylerm09's Avatar
But anyway why do you have the hvac module hooked up when testing to see if the analog request works?
Old 08-31-2021, 10:40 AM
  #117
TrendSetter's Avatar
great PDF reports. I have the same power supply too
Old 09-01-2021, 01:16 AM
  #118
Jouko Y's Avatar
Hope this is not duplicate post? (Last message had attachment image, not allowed for beginners?)
This is how I wired A/C, now FAN(s) are on when A/C is on.
Edit: without pressure sensor.
https://universalpatcher.net/wp-cont...ensor-Fans.png
Compressor type: Analog.
Maybe gnd to pin 55 is not required?
Old 09-02-2021, 05:57 PM
  #119
The HVAC module communicates by the GM class-2 serial protocol used at that time. It's a digital signal, not analog. I used the HVAC module as a baseline test. I wanted to confirm first that the PCM would operate as expected as it arrived from GM. Because the donor vehicle for the PCM was a 2004 Silverado or Sierra, the way the AC system was controlled from the factory was with that module. So before I modified the PCM, I wanted to verify that I could correctly interpret the response of the PCM when AC was requested through the HVAC module. This was a confirmation that my bench-top setup was correctly wired up and working properly.
Once that was done, I could then proceed to modify the PCM, and try to activate AC with just a 12 Volt signal. Which was also successful, but only after I implemented the fix to the motherboard. Before that, only the HVAC module would activate AC. Now, I can program the PCM to accept either a serial data or analog AC request.
The following 2 users liked this post by rocketmench:
G Atsma (09-02-2021), vdiaz133 (08-31-2022)
Old 09-02-2021, 07:27 PM
  #120
350SS's Avatar
that's a hell of a contribution to make to the ls swap world esp with only 5 posts here haha
never ceases to amaze me how smart some guys on here are... thanks for sharing this, i'm sure this will be helpful to lots of people
Quick Reply: A/C request Blue/Green connector ECU
