Hooker mounts or headers for the 66 GTO?
Engine height is the key in the 64-67's. It has to be high enough to clear the steering center link while still remaining as low in the chassis as possible for hood clearance, tunnel clearance and driveline angle. This makes oil pan choice crucial as well. I used the mast hotrod pan and still slightly "clearanced" it with a grinder for more centerlink and tie rod clearance.
Andrew
Andrew
Andrew
Because of their unique geometry, the LS swap components we've released over the last two years will not work for other applications in 9 out of 10 tries to do so, which is why we discourage their use in such a way as much as possible. Hooker still offers universal swap plates for such applications for folks that want/need to go that route.
