newest aje kmember in fox with lsx
Old Jul 31, 2014 | 04:48 AM
foxsl's Avatar
Default newest aje kmember in fox with lsx
Hi I was wondering if anyone has info on the newest batch of the aje tubular kmember in respect to any issues in an 87-93 fox while using stock A-arms (aka control arms) with stock coil springs AND stock power rack w/stock fox steering shaft.
Thank you
Old Jul 31, 2014 | 12:11 PM
foxsl's Avatar
Aje says it will work with the stock steering parts
Old Jul 31, 2014 | 04:43 PM
foxsl's Avatar
Has anyone tried the Aje kmember with hedman hustler ls swap headers or dynatech?
Old Jul 31, 2014 | 04:48 PM
SMAX's Avatar
My buddy just got a new AJE k member, and even though we don't have everything final bolted in it looks like a set of 98-02 f body pacesetter long tube headers are going to work with some minor modifications (small dents and dimples). Once we get everything in it's final resting place I will shoot some pictures of how everything worked out.
Old Jul 31, 2014 | 06:11 PM
foxsl's Avatar
That sounds great thank you
Old Jul 31, 2014 | 07:08 PM
mangler's Avatar
I just put an AJE in my 90 fox. I was originally going to use factory springs and A arms but got a great deal on some coilovers and went with qa1 eco a arms for 150. Everything bolted up good. Stock power rack went on fine and steering shaft bolted up. You have to pull the shaft from the firewall about 3/4 of an inch with a prybar though. It telescopes.
Old Jul 31, 2014 | 07:27 PM
foxsl's Avatar
That worked out pretty well and yup Aje told me today Ill have to disconnect shaft then get headers on and reconnect steering shaft. Thanks for the info
Old Jul 31, 2014 | 07:32 PM
foxsl's Avatar
What intake are you using as I just got mixed news on truck intake with a 2.5 inch cowl.
Old Aug 1, 2014 | 11:32 AM
mangler's Avatar
I plan on using the truck intake with a 2.5 cowl. I don't have it all together yet though. Engine and trans are in but fabricating the turbo kit now.
Old Aug 1, 2014 | 12:33 PM
Joe Lluvia Avila's Avatar
My AJE worked with my stock PS rack and stock a-arms. no issues with mine. I just used the supplied bolts they sent.
Old Aug 1, 2014 | 12:39 PM
Im using the stock truck intake...it fit with no issues. i just remove the evap port sensor and plugged it. i shaved the intake for cleaner look and a bit more clearance with stock hood.
Old Aug 1, 2014 | 03:02 PM
foxsl's Avatar
Oh wow that's impressive how much room you have, are you using aje engine mounts as well?
Mine is itching to go in, it's an lq4 from a savanna van but they seem the same intakes as from a truck
Attached Thumbnails newest aje kmember in fox with lsx-2014-07-28-03.09.08.jpg
Old Aug 1, 2014 | 03:05 PM
foxsl's Avatar
What brand headers are you using?
Old Aug 1, 2014 | 03:37 PM
2010 camaro ss manifolds. fits like a glove. even with the heatshields on.
Old Aug 1, 2014 | 04:08 PM
foxsl's Avatar
That's impressive, thanks for all your help.
