can pcm tuning cause this?
Old Jul 31, 2014 | 06:46 PM
not2oldchevy's Avatar
Default can pcm tuning cause this?
Long term fuel trims idle at 18 goes to 25 and stays. I have checked for all known problems several times. It throws lean codes. All I have left is pcm programing could this cause it. PSI harness and reprograming. 5.3 4l60 I drove the donor truck that everything came out of with no codes.
Old Jul 31, 2014 | 07:49 PM
i r teh noobz's Avatar
If it's only at idle then it could be a tuning issue. Are both banks acting the same?
Old Jul 31, 2014 | 10:17 PM
CutLS's Avatar
Can you read short term fuel trim. Sounds like you have a huge vacuum air leak.
Old Aug 1, 2014 | 01:04 PM
Idle is 18 any rpm above idle goes to 25 both banks are the same. No vac or ex leaks. I have checked every thing changed fuel pumps and fpr, It threw no codes in donor truck. Short fuel trim is ok.
Old Aug 2, 2014 | 09:00 AM
my406cid's Avatar
What does the 02 voltages look like and are they toggling rich lean n how fast.
