looking for conversion help/tips
Old Aug 16, 2014 | 12:54 AM
lilj87's Avatar
Default looking for conversion help/tips
i wanna do a lsx on a 79-85 riviera or eldorado. and was wondering if anyone has tried yet. means they fwd but mounted like old motor
Old Aug 16, 2014 | 06:25 AM
lsxRanger94's Avatar
Bop adapter plate, custom engine mounts, flat flexplate with spacer. exhaust manifolds are anybody's guess. Should be able to cut and weld up some factory manifolds or build your own headers. Accessory drives are dependent on clearance to radiator. Truck accessories may work. Intake manifold may be able to use truck under that hood. oil pan may be an issue with transaxle. GTO maybe?
Old Aug 16, 2014 | 09:31 AM
garys 68's Avatar
You'll want to research hooking a th425 to an LS motor.
It's been done, but more difficult than a rwd trans.
Old Aug 16, 2014 | 08:07 PM
tonypaul's Avatar
I think those years had the th325 which was a real weak trans, I had a '82 Riveria a long time ago and it had the th325. My advice find something else that has rwd. I have a th425 in my garage and was going to use it with a LSx in my Lambo kit car and it just wasnt worht the trouble...
Old Aug 16, 2014 | 08:35 PM
https://ls1tech.com/forums/conversio...transaxle.html
Old Aug 16, 2014 | 09:17 PM
garys 68's Avatar
Yeah, but are there any th325 threads here?
I was actually referring him to your threads. Didn't think the mounting of a 325 would be significantly different from the 425.
Old Aug 18, 2014 | 10:12 AM
Oscar Will's Avatar
You know that Chevrolet built a bunch of Impala SS front drive cars with 4T65E transmissions mated to LS engines...I would look into that drivetrain. Why not stay front drive with something the engineering was already done on? I think they were around 1999-2001, something like that and they actually drove pretty well.
Maybe I'm just lazy but I can envision that classic with a 6.0L, mildly tuned as a really awesome cruiser.
