New to 5.3ls... need help getting it started
1)verify harness is pinned correctly
2) Check continuity between crank sensor plug and PCM connector terminals.
3) check continuity between pcm and coil connectors terminals
4)check harness from coil connector terminals to each individual coil terminals.
5)If harness fails find issue and repair or send back
6) If harness passes, verify input from crank sensor to PCM and PCM coil output to coils.
We are assuming all pink wires are keyed hot in crank and run.
I had another one where the customer bought a Painless harness. Turned out they (Painless) had a bad connection on a live wire where it branched out. Redid the connection and all was well.
Since then I have used a direct feed to the PCM for the permanent live, with a fuse of course.
I have found pinouts in various places, and just Googling "2001 Chevy Tahoe PCM pinout" etc normally brings them up
Martin
Also make sure you have about 58-60 psi of fuel pressure.
Fuel pressure is spot on.
I am using an ignition relay, and it stays energized while cranking.
Yes on the pink and orange wires.
I did not change the cam shaft...all stock except for headers.
So tell me more about gen 4 engines not having tone notches...if that is the case, then why is there a cam sensor behind the intake manifold? Or is it a cam sensor at all. What ever it is, it did not give me the same readings as the crank position sensor that is located behind the starter.
Sorry if I am rambling. I did send the PCM and wiring harness back today to have the two units checked by the experts at Novak. Sure hope the find something.
Sent the wiring harness back to the folks at novak and found a break on one of the ground wires. Life got in the way though and I was just able to plug everything back in. Fired right up and runs like a champ. Sounds beefy too.
Trying to keep the original Jeep inst cluster... any thoughts on an engine temp sensor adaptor from the metric 5.3 port to the standard amc port???
