No power to fuel pump in run position
When i put the key in the run position I hear noise of the fuel pump for a fraction of a second trying to run then it stops. I hooked up a test light and it only lights for a split second. Until now when the key was placed in the on position I would hear it run for a full 2 seconds and then shut off until I started the engine.
I have tested the pump independent of the PCM and it works fine, and verified that the corvette FPR is also working correctly.
Anyone have any ideas what is going on?
It seems to me like the PCM is deciding that something is wrong and is turning off the fuel. Could this be a crank sensor? I was troubleshooting a problem with MAP sensor and MAF sensor codes (I suspect a vacuum leak) and suddenly this issue began.
The car was running? Any crank or cam sensor codes?
I am thinking the PCM is "deciding" for some reason that it should not supply voltage for coil, injector, or fuel pump for some reason. Still troubleshooting but thought if I posted here I might get some advice to hurry up the resolution process.
If all is good, check engine grounds, relay ground, and fuel pump ground. Corrosion build up on a swap is not uncommon if surfaces were not completely clean of paint and rust before attaching ground wires.
I did 2 things. I removed the negative battery post for several hours and I moved the routing of the crank sensor wiring because it looked like it was up against the exhaust flange. When I inspected the wiring I could not find a burnt location on the wires so I really think it must have been the battery being off reset something in the PCM.
Now I am getting the P0101 (MAF) code immediately upon start up. But it does run and the fuel pump primes for 2 seconds now like it should.
