05 5.3 swap in 55 chevy
Swapping a 05 5.3 in a 55 following lt1swap pin out but on first fire up could not get generic code reader to scan anything but scanner than u had to type vin in would read codes I've seen where a ground to computer could be the problem what ground should I look for all the ones I cut into went to common grounds is there something in lt1 swap I missed?
