Exhaust size question
Old Sep 22, 2014 | 11:47 PM
ChrisCoufal's Avatar
Default Exhaust size question
Curious as to y'alls opinion on exhaust pipe size for my build. This will be going into a 66 C10.
It's currently a stock LQ4 with 1-7/8" mid length DT's. Plan for it later will possibly be H/C/I and a tune.
I'm thinking about using the FlowMaster U-Fit kit so that I can fit it how I want and weld it up myself. My question is should I spend the extra $20 and run full 3" (my collectors are also 3") or just stick with the 2.5"?
Is there any advantage for that extra half inch? I could see the disadvantage being space and fitment in tight spaces.
Thoughts?
http://www.jegs.com/p/Flowmaster/Flo...60019/10002/-1
Old Sep 23, 2014 | 03:37 PM
https://ls1tech.com/forums/generatio...h-exhaust.html
found my answer. Thanks
Old Sep 23, 2014 | 03:47 PM
thunderstruck507's Avatar
You will want 3" for a heads and cam car/truck, period.
Old Sep 23, 2014 | 05:48 PM
yea that's what I decided upon. I'm assuming I should also go with an X-pipe over an H-pipe? The kit comes with an H-pipe, but everything I've read says go with an X instead?
Old Sep 23, 2014 | 06:02 PM
lsxRanger94's Avatar
I thought you were adding a turbo later?
Old Sep 23, 2014 | 06:12 PM
That is not going to be for a few years. I need this to drive for the next 18-24 months.
Old Sep 23, 2014 | 06:27 PM
Since this is only "temporary" exhaust, you will end up tearing half of it or all out depending on where you run your down pipe for the turbo. Unless you run a TT setup and want full exhaust. So spend accordingly.
Old Sep 24, 2014 | 11:23 AM
I wouldn't fret over x or h. I have no crossover at all on mine. If it comes with an h, just run the h.
