2011 Corvette Ls3...in a 71 Firebird-questions...
Old Oct 11, 2014 | 12:02 PM
cpd004's Avatar
Default 2011 Corvette Ls3...in a 71 Firebird-questions...
I'd like to know if he 2011 Corvette Ls3 that was originally backed by an auto trans would have displacement on demand, active fuel management, etc. I am interested in swapping this engine (need to find a trans) into my 71 Firebird. It would come with all accessories, harness and PCM. Not sure if the accessory drive would work in my car. I'd like to keep the AC system functional. I've done a search and haven't been able to come up with much on the engine or this particular type of swap. Any help would be greatly appreciated.
Old Oct 11, 2014 | 01:43 PM
Docked Wage's Avatar
An LS3 does not have AFM.
It's the L99 from the Camaro that has AFM and VVT and Flex Fuel Capability.
Old Oct 11, 2014 | 02:57 PM
cpd004's Avatar
Thanks. It appears that the AC compressor mounted down low on the passenger side might be in issue with the stock subframe. Does anyone know for sure? I thought I read somewhere that a bracket from Kwik performance might help but can't find the article anywhere. I Plan on getting the stock harness reworked and PCM recalibrated. Are there any other issues anyone knows of that I might run into with this engine in an early 2nd gen F Body?
Old Oct 12, 2014 | 08:37 AM
Project GatTagO's Avatar
If you want to retain the stock LS3 AC location then you will have to make a pocket in the front crossmember. This isn't a big deal and can be done easily.
I would also go with the new Holley F-body mount kit as it was designed to to mount the engine as low as possible, which is critical for proper driveline angles. Holley also offers some alternative AC mounting solutions.
Andrew
Old Oct 12, 2014 | 10:18 AM
cpd004's Avatar
Thanks for the info. It appears that Kwik Performance has an AC bracket that mounts the compressor up higher that might solve that issue. I also found A kit from brphotrods that included engine mounts and a crossmember. It's a bit pricey but seems to be well liked from what I've read.
Old Oct 12, 2014 | 10:20 AM
cpd004's Avatar
Here's that kit:
http://www.brphotrods.com/products/2nd%20gen%20F%20products/index.html
Old Oct 12, 2014 | 12:09 PM
If it was my car, I wouldn't use it...but that's me. I am not a fan of how they to the frame stands with the poly inserts. Those will transmit a lot of engine vibrations. The Holley mounts use the later style clam shell mounts which a strong and will isolate the engine better, not to mention making sure it is mounted low in the chassis.
https://holley.com/products/ls_power...parts/12512HKR
Here is the T56 cross member:
https://holley.com/products/ls_power...parts/12616HKR
There is also one for automatics.
Andrew
Old Oct 12, 2014 | 12:48 PM
cpd004's Avatar
Andrew, thank you for all your help!
I read on Holley's site that I will need the 2292 clam shells to use the Holley engine mounts. Since my sub frame was born Pontiac, wouldn't I have to drill new holes in order for the Holley mounts and the 2292 clam shells to allow the engine to be secured to the sub frame?
Old Oct 12, 2014 | 12:58 PM
My GTO frame already had the needed holes, but even if you don't have them, the Holley instructions provide a template, so it should be very simple.
Andrew
