LSA from CTS-V
Old Oct 16, 2014 | 09:14 PM
cryptonomad's Avatar
Don,
As Ken said, you can use the OEM ECM, wire in the FPCM and pressure sensor, with the vaporworx and ctsv/zl1 pump. that gets you PWM fuel pressure at OEM specs using oem parts. Make sense? Doing exactly that on the project I'm working on.
https://ls1tech.com/forums/conversio...retro-fit.html
Old Oct 17, 2014 | 09:21 AM
dhutton's Avatar
Originally Posted by cryptonomad
Don,
The Vapor Works controller does not deliver the 65/87 psi boost referenced pressure specified in the GM performance LSA controller instructions (and verified by a call to the GM tech line). This has been confirmed by Carl Casanova, the owner of Vapor Works. Can it be made to work through extensive dyno tuning, yes it likely can. But it will not work with the controller as it comes tuned out of the box.
Ken had extensive dyno tuning "due to the mismatched components" of his system. I am guessing that included the injectors combined with the Vapor Works controller. I am also guessing you will have to do similar tuning with your setup unless you change the injectors. Otherwise you may be running very lean at the top end and risk engine damage...
Just my two cents gained after countless hours on the internet, emailing with Carl, and talking with the GM tech line....
Be sure to post up your results when you get your install up and running.
Thanks,
Don
Old Oct 17, 2014 | 10:14 AM
Thanks,
Don
Understood Don. I'm not using a vaporworx controller, I'm using the factory fpcm that is ecm referenced, and intend to leave it stock tuned.
Old Oct 17, 2014 | 11:01 AM
dhutton's Avatar
OK, I misunderstood your post. This is different from what Ken is doing. He is using the Vaporworks control module.
Thanks, this is the information I was looking for.
Don
Old Oct 17, 2014 | 07:51 PM
kwhizz's Avatar
I couldn't run the stock controller because of not using the 6L90E trans.......its all tied together...........I know Nickey did a lot of Tweaking on my set-up.........we were just talking about doing the pulley upgrade along with a few other things and at that point they said we would need to modify the fuel system and Injectors..........I didn't understand the exact nature of your question.......Sorry
Ken
Old Oct 17, 2014 | 08:08 PM
dhutton's Avatar
Ken
No need to be sorry. I think I confused a lot of folks with the way I asked my question.
Thanks Ken,
Don
Old Feb 20, 2015 | 01:05 AM
CarlC's Avatar
Carl has already confirmed that his system cannot support the requirements of the stock LSA controller. I read your thread and it seems that you had extensive dyno tuning done. I suspect part of this tuning was to compensate the difference between the fixed Vaporworks 60 psi versus the stock LSA tune boost referenced 65/87 psi. My goal is to avoid tuning and to use the stock controller as programmed.
I agree, the Vaporworks is a great product. It just can't support the specified LSA requirements without extensive tuning. This is also the reason that Spearworks supplies new injectors with their LSA setup, to allow fixed pressure without boost referencing. It would be interesting to see the duty cycle of the injectors in your tune at WOT Ken.
Thanks,
Don
UPDATE:
The GM spec's are incorrect for the LSA/E-Rod. The fuel delivery requirement for all GM LSA crate engines is the same. The 87psi is what is needed for the ZR1, not the LSA.
A new version of the instructions should be released soon with a much more practical fuel pressure range. Using the standard VaporWorx PressureWorx system should work quite well in manifold referenced mode. http://www.chevrolet.com/content/dam...19260164-1.pdf
It made no sense that the fuel pressure requirement for any of the LSA-based crate engines had a fuel delivery requirement far, far outside of the performance envelope of the ZL1 and CTS-V fuel modules.
Carl Casanova
VaporWorx
