Drive accesories for s14
Old Oct 13, 2014 | 03:06 PM
laurentj23's Avatar
Default Drive accesories for s14
Hey guys,
I have a few questions for those of you who have done this conversion in this particular car. My engine doesn't come with the accesories, so I need to sourced one out. I already gotten a few parts. Do i need to get the alignment bracket like the one holley sale?
https://www.holley.com/products/acce...rts/parts/21-2
or individual brackets will suffice? Do i need to get the main brackets if i just need one item from holley such as the powersteering pump?
Any help?
thanks
Old Oct 14, 2014 | 09:49 AM
2muchboostNY's Avatar
Just get the main brackets for the specific accessory kit you are going with to make it easiest. Ex: Fbody accessories get Fbody brackets. I went with the CTS-V setup to free up as much room as possible and use an LS2 Balancer which is the one used for the CTS-V setup. Unless you want to go with after market for a reason like Holley, stick with OEM brackets which are usually cheaper from what I have seen.
