42# Ford Green Top Injectors
Old Oct 13, 2014 | 06:43 PM
Mike Blanco's Avatar
Default 42# Ford Green Top Injectors
My engine builder recommended I buy 42# Ford Green Top Injectors. I am a bit confused b/c these are going into a LQ4 motor w/ the GM wiring harness.
So I am requesting a bit of information from you guys as to exactly what does he mean, and where can I find them? Thanks
Old Oct 13, 2014 | 08:07 PM
S10xGN's Avatar
I got mine used off E-Bay for $160 and sent them to be flowed ($80). They were all spot-on perfect in this case...
Ford SVO Green Top fuel 42 lb Injectors
Ford Part # M-9593-F302
Bosch Part # XL3V-A9A and 280150558
Old Oct 13, 2014 | 08:20 PM
So...even though these are "Ford" they will fit my GM wiring harness?
Old Oct 13, 2014 | 08:24 PM
S10xGN's Avatar
There are only two types of GM FI connectors, these fit the early style that GM used up until the mid 2-oughts. You can google the different connectors to see which ones you have. IIRC, they are referred to as either "Bosch" or "mini-timer"...
Old Oct 14, 2014 | 08:11 AM
71ANTICARB's Avatar
Yes they will plug into the gen3 harness. They are an "ev1"style injector.
Old Oct 14, 2014 | 09:51 AM
EFIHARNESS's Avatar
The green tops are the ev1 style connector.
# 4 above is incorrect, as there is at least 3 types of gm fi connectors for ls engines.
ev1,early bosch, rodchester= f body, some early corvette's, and most aftermarket injectors
ev6=ls2, ls3, ls7, and most current engines
truck=4.8, 5.3,6.0, 8.1, and a lot of marine stuff
above list is by no means complete.. Steve
