4-Valve LS Heads at SEMA?
Old Nov 7, 2014 | 11:43 PM
ryguy2588's Avatar
Default 4-Valve LS Heads at SEMA?
Has anyone heard more about these heads and this setup? Seems pretty interesting. Supposedly it's outrageously expensive. I didn't see anything through searching on here, so if it has already been talked about, then I apologize in advance.
http://www.hotrod.com/events/mercury...-at-sema-2014/
Old Nov 8, 2014 | 12:01 AM
1320's Avatar
Normally you would be refferring to aeroheads I think...which long ago were dominion heads. I ran dominion heads On a 396 lt1 in the 90's. I ve seen there 4 valve ls heads at sema....but I did not see them this year, but they could have been there.
I did see mercruiser though....with dual over head valve 4 valve heads on an ls.
No price (Id gues 6000 area) and they look cool as hell, I posted a pic in another thread in forced induction. I did find it strange that they had them displayed with NO flow numbers.......The aero 4 valve heads are in the 400 + cfm area.....awesome heads, but no one ever uses them primarely because all the class rules say 2 valve heads.....most sanctioning bodies dont allow 4 valve heads on an original 2 valve engine......so who is gonna spend 60004 on heads for the cool factor only....no racers can really use em and thats the market
Old Nov 8, 2014 | 11:06 AM
ryguy2588's Avatar
I think mercuiser is what my friend saw. He was sending me pictures of the heads. He was curious to why they didn't have any flow numbers as well, but the article I posted said it should be in the 400 cfm area. It also said they haven't done extensive durability testing on them yet.
I was just trying to learn more about them and maybe find a comparison on the DOHC versus the normal single cam LS's.
Old Nov 8, 2014 | 11:32 AM
"MAC"'s Avatar
With those heads you would still use the single cam. It states in the article that a blank circle goes in place of the cams in the DOHC bc no load is put on them. Hope this clears things up a bit.
Old Nov 8, 2014 | 11:43 AM
ryguy2588's Avatar
Ok I guess technically not a DOHC, but it uses one cam per head, so two cams. That's more what I meant. From previously stated, not many people use them, but does anyone have results from these heads? Dyno numbers and graphs?
Old Nov 8, 2014 | 11:59 AM
1989GTA's Avatar
Look at the depth of the accessory package. I am not sure how that will fit into our cars. In a boat no problem. Maybe some vintage cars that came with an inline 6 cylinder there might be enough room.
Old Nov 8, 2014 | 02:12 PM
"MAC"'s Avatar
People stuff BBC in our cars if they can fit im sure this would fit.
Old Nov 8, 2014 | 07:33 PM
33willys's Avatar
Default 4 valve heads
Over the years I have heard and seen attempts at DOHC heads on a Chevy small block. One problem that kept coming up was the head bolts/studs were in the wrong place.
Old Nov 9, 2014 | 11:32 AM
Jay Gadsby's Avatar
From what I gather looking at the various off shore sites, I think these will make their way into boats more often that not. Lots of people want to stuff LS engines into their boats, but it's hard to beat the al over torque of a BBC. The article states that the flow numbers are well north of 400 as cast. And if you look closely, there are two cams per head, so it is a DOHC setup.
I am sure more testing will come along. Based on the price of a normal Mercury Racing engine, I am sure they will not be cheap. I have had my hands on a couple of their engines that are WELL into the 6 digit territory. Only time will tell.
Old Nov 9, 2014 | 11:53 PM
ryguy2588's Avatar
I heard their complete motors are in the $300,000 range. What do you mean the head studs were in the wrong place? Like they casting holes didn't like up with the block's?
Old Nov 10, 2014 | 02:38 AM
Jimbo1367's Avatar
What ever happened to Nick Arias's 4 valve heads?
Old Dec 11, 2014 | 08:23 AM
midnightbluS10's Avatar
You screwed that way up lol.
The in block cam is swapped to a blank, not the ones in the heads. Wtf? What would even be the point of using them if the cams were blanks and didn't control the valves? Did you even think about what you were saying?
It has 2 cams per cylinder head, hence the DOHC. Dual cams over each head. Just as SOHC means a single cam over each head.
Going by your logic, DOHC means 2 cams, one over each head. Which is wrong. So SOHC would mean only one cam shared by both heads, and somehow still mounted above both heads and controlling the valvetrain. Smh.
No. Just no.
DOHC means 2 cams over each head. 4 total.
SOHC means 1 cam over each head. 2 total.
OHV means valves mounted overhead of the single cam, which is in the block.
So you "built drag Hondas for years" but you don't know what DOHC AND SOHC means? And can't identify what you're even looking at? I call
Old Dec 11, 2014 | 10:51 AM
Mike52's Avatar
No. Just no.
OHV means valves mounted in the cylinder head. Example, the flathead Ford(and many other flathead engines) had the valves mounted "overhead of the single cam" as you described but the valves were in the engine block, hence the name 'Flathead'. Be careful before you wave the BS flag around because you just got hit with it!
Old Dec 11, 2014 | 12:06 PM
gsteele's Avatar
His main point was DOHC vs SOHC. The OHV comment was almost a throw away line. So in the same way that you took him to task could not some one point out that OHV does not mean "valves mounted in the cylinder head" but valves mounted over the cylinder head which was in fact your main point?
