Need Help With A/C Compressor brackets
Old Nov 25, 2014 | 01:02 AM
Dale002's Avatar
Default Need Help With A/C Compressor brackets
Can anyone suggest a bracket/compressor combo that would allow me to install the A/C compressor in it's original place but closer to the block on a 98 LS1 out of a firebird. I have about 10.5 inches from center of crank HUB bolt to chassis. I was looking at the late model Silverado brackets and compressor and they seem as they will take less space than the original set up.
Old Nov 25, 2014 | 06:01 AM
oldgoat69's Avatar
If you are looking at the truck brackets, call it 99-06, they are low on the pass side. I don't think the pulley alignment will work with the F-body water pump. I am sure others will weight in as well. I can't really answer on the 07-13 truck.
If you need pictures of the earlier set up I can get you those.
Old Nov 25, 2014 | 07:21 AM
Aston Tibs's Avatar
Alan Grove Components in Kansas makes AC Compressor brackets for the Sanden 508 AC compressor. I am using the low mount passenger side. My kit # is 143R. If you think that will work for you, contact me, because I ended up with an extra bracket that I can sell you for cheap. I had my brackets powdercoated and then misplaced this one and had a to buy another. Of course the day I installed the replacement, I found the original.
Old Nov 25, 2014 | 07:57 AM
Cuate's Avatar
Default C10 5.3 Ls swap with AC compressor
I installed dirty dingo adjustable motor mount plates on my 5.3 engine and had to remove the AC bracket and compressor. Does anyone know a way to still use the 5.3 stock AC compressor? I'm planning on installing engine on a 1968 chevy truck. I didn't read the note on dirty dingo pg where it states it will not work with stock AC compressor. This engine is from a 2001 Tahoe and originally has AC compressor on bottom passenger side. Adjustable plates where pricy and I really was not planning on spending money on another AC compressor or brackets. Any ideas or solution will be appreciated.
Old Nov 26, 2014 | 01:27 AM
Dale002's Avatar
pm sent
Old Dec 12, 2014 | 09:43 AM
Gooker928's Avatar
Default Bracket
Don't quote me but I think I read somewhere that a 96 Silverado ac bracket can be used.
It puts the compressor on top on the passenger side.
I looked into it on my 63 swap but ended up using a different adapter that didn't block the stock compressor location.
My compressor fits perfectly inside where the frame is notched.
Old Dec 12, 2014 | 11:00 AM
tfi racing's Avatar
95-98 Truck mounting brackets will not work at all on the LS engines.
