e36 Lq9 swap - need help!
Old Dec 6, 2014 | 01:42 AM
LavJordan's Avatar
Okay then I probably will have to wait and hunt down a F-body one.
BTW Just quick question unnatrl, do you know if the 318is have any different rotors than the M3. I was about to buy some slotted rotors but remembered the M3 had different brakes, and I dident know if that included rotors or just calipers. Which made me worry that the M3 rotors might require M3 brakes.
Old Dec 6, 2014 | 01:45 AM
unnatrl's Avatar
Originally Posted by LavJordan
Okay then I probably will have to wait and hunt down a F-body one. BTW Just quick question unnatrl, do you know if the 318is have any different rotors than the M3. I was about to buy some slotted rotors but remembered the M3 had different brakes, and I dident know if that included rotors or just calipers. Which made me worry that the M3 rotors might require M3 brakes.
M3 rotors, calipers, spindles and struts are unique to the M car.
Old Dec 6, 2014 | 08:43 AM
csmc711's Avatar
Would a vette oil pan do me any good or would that have clearance issues still in comparison to the F body one?
CSMC, I got a quote for a oil pan from the yard, he said about 100-150 depending on which car it comes off. If you honestly want one I could snag one... unless that was sarcasm
What year vette are you talking and if you can get one to virginia for $130, I am serious as a heart attack! It would have to be a f-body pan though. I cant seem to find anything else that would fit the Beemer.
Unless your road racing on a track, I would not worry about the brakes. I just spent last weeek studying the whole fiasco. In fact, if you send me a f-body oil pan, I will send you the 330i brakes calipers, carriers and pads I just got that I decided not to go with. They are larger than the M3's and bolt right up. No spindle changes or anything. I just changed my mind and will be sticking with the stock brakes.
Old Dec 8, 2014 | 01:38 PM
LavJordan's Avatar
Ill keep your name in mind. Probably a atleast a month before I really start hunting one down so I doubt I would be able to get you one quickly but ill keep a eye out at the yards.
For the BMW, Im gonna get new rotors because its got 260k on the clock and I dont think they have been changed once+a new set of pads. No need for a whole new caliper setup but thanks!
Old Dec 8, 2014 | 02:48 PM
csmc711's Avatar
Well, you said "do you know if the 318is have any different rotors than the M3"
Yes, they are diff. To go with M3 rotors, you need to change the spidle/knuckle, calipers and caliper brackets. Then you need pads and specific rotors. The 330i setup "I" have will give you a larger rotor than a M3 and bolt directly to your spindles. All you would need then is the new rotors you are getting anyways.
Okay, well, kind of need the pan soon so I will have to pay out the azz for it off of GM parts so I can get this mockup going. Good luck on the hunts.
Old Dec 8, 2014 | 03:03 PM
TipsyMcStagger's Avatar
I guess things are different depending upon what part of the country you're in but I've yet to see an LS1 F-Body at any of the pick-n-pull yards in the Tampa area. Nothing but V6 cars.
I bought my F-Body pan setup from Super Chevy Performance.
Tipsy
Old Dec 8, 2014 | 07:19 PM
LavJordan's Avatar
Huh? Thats funny ^ Here it is anything and everything, which includes those old V8s. They are no shortage, I can tell you that
