PORSCHE conversions Check in.
I'm thinking of using a L92 or similar, since they are common in junkyards for $3-4k. Planning on buying the Renegade Hybrids kit, their mechanical water pump kit, and intake. Not planning on getting the power steering kit. I'll either adapt the LS PS pump or have no power steering. Trying to do it as cheap as I can, but it's pretty easy to be cheaper than a rebuild, since the Porsche engine rebuilds cost $10-20k. If I'm spending that much, why wouldn't I want another 100-200hp?
Has anyone passed emissions with their swap? Don't need it to be smog legal here, just need an OBDII port that says the car is OK.
https://www.dirtydingo.com/shop/mobi...oducts_id=1691
I'm surprised you would need this, since the PS lines have to go all the way to the front of the car. I would expect you would need all the pressure you can get.
https://ls1tech.com/forums/conversio...-wire-vss.html
I'm not clear how that applies to a porsche or why it is necessary. Seems most people didn't bother hooking up the VSS to the GM ECU.
