PORSCHE conversions Check in.
Old Sep 14, 2017 | 04:56 PM
  #101
dcd215's Avatar
Default Phase 1 done
Nothing elegant-just wanted a reliable 996 .One goal was to stay away from the Jegs and Summit catalogs -so far so good .All the emissions stuff is hooked up and working, as well as the cruise control .I may tackle traction control this winter as well as the a/c .
The cooling system is working fine ,which was a concern going in .The intake is fugly but is running about 15 degrees over ambient which isn't too bad .
Phase 2 is upgrade the 5300 heads and cam ,it would drive a lot better with a higher rpm motor .
The only thing I don't like is the numerically high final drive ratio -but have not found a justifiable solution yet .
Old Sep 14, 2017 | 06:41 PM
  #102
hayabusa's Avatar
Looks damn good!
Old Oct 12, 2017 | 07:54 AM
  #103
Outlaw 911's Avatar
My new build.....
https://ls1tech.com/forums/conversio...sche-swap.html
Old Nov 12, 2017 | 03:58 AM
  #104
SHARKBITEATTACK's Avatar
saw a LS1 996 at SEMA. Belong to anyone on here?
Old Nov 12, 2017 | 11:57 AM
  #105
The Dark Side of Wil's Avatar
315/25-19 tires?
Too bad he put them on 16 inch wide wheels so they're stretched and useless.
Old Nov 12, 2017 | 01:07 PM
  #106
White Out's Avatar
That had an LS?? Sweet!
Old Nov 12, 2017 | 10:10 PM
  #107
Originally Posted by The Dark Side of Wil
315/25-19 tires?
lol yea, I'm personally not a fan of that look but I enjoyed the rest of the car haha
Old Nov 14, 2017 | 06:53 PM
  #108
AndrewRS's Avatar
https://www.youtube.com/watch?v=AlSij7zFhAc
I'm not sure he's on here, but he is part of the "Swapped Porsche" Facebook group.
Old Mar 9, 2018 | 09:41 PM
  #109
ca12los's Avatar
Default iron block NOS?
Kieferskustum,
I was wondering how your transmission is handling the power levels now with the 175 shot. I saw the picture of the tire, that's impressive!! You will need to put a billet side cover on that the transmission. Since the spider gears sheared, it got me wondering what would have happened with a LSD in place. you would have snapped an axle me thinks.
Old Aug 8, 2018 | 01:04 AM
  #110
driveability's Avatar
Originally Posted by shanghai_todd
For the guys out there that did electric power steering is anyone running anything else other than the RH conversion kit or standard TRW pump? Came accross this pump on Fleabay that is used in Volvos that is pretty cheap and similar to the TRW design. Unsure on the specification but don't see why it would not work unless the fluid is completely different or much lower power output.
BTW, what size AN fittings and hoses are used with the RH kit? Is the high pressure and return both 6AN or are the different sizes?
http://www.ebay.com/itm/142203722145...%3AMEBIDX%3AIT
I know this is an old thread but I used the second gen Mr2 electric power steering pump twice on my two V8 914s. No kit just fabbed it up. These pumps are built like tanks and worked great.
