Valve cover adapters
Old Dec 5, 2014 | 10:19 PM
jozw30's Avatar
Default Valve cover adapters
Would like to use later chevy center bolt valve covers on my LS2. Guessing that since I don't see any adapters for sale, that it can't be done?
Can anyone confirm whether this is not possible or is it just that nobody sells an adapter?
Thanks!
Old Dec 6, 2014 | 12:58 AM
unnatrl's Avatar
Are you referring SBC valve covers? If so adapters are made for the older perimeter style. If you mean late LS covers, the LS2 uses the center bolt LS valve covers (as long as it has the original 243 heads).
Old Dec 6, 2014 | 07:16 AM
jozw30's Avatar
I am wanting to adapt a center bolt SBC valve cover to the LS center bolt head.
Old Dec 6, 2014 | 08:24 AM
oldgoat69's Avatar
Anything is possible. From a first look it appears that the bolts may be on close to the same plane. The first step would be to see how the early valve cover bolt holes align with the LS. Then make patterns and have them watercut. My first guess is that the adapters might need to be 2 layers laminated. The first a pattern of the LS outline with the center bolt hole pattern. The second being a "spider" early pattern center bolt layout. Then use a double ended stud to hold them together.
Old Dec 6, 2014 | 02:23 PM
jozw30's Avatar
They are close and that is probably more an issue than if they were more different. I Need to really think about this. It's a lot of work and I have a bad feeling it will be a leak issue.
I wish I could get these fit down better on the passenger side over top of the LS covers.
Two problem areas are the oil filler neck/cap and the pressed in PCV tube. I will have to hack a big notch in the SBC to clear that thing.
Wish I knew how to get that tube out without trashing anything, but it's really tight and hidden by the baffle.
Old Dec 8, 2014 | 06:07 AM
oldgoat69's Avatar
Put up a picture of what you are attempting.
Old Dec 8, 2014 | 07:06 AM
jozw30's Avatar
I will go tout take a picture later today if can.
I picked up some long 6mm screws and the holes line up enough that all 4 screws come up thought the SBC cover. They are all a bit off center in the holes, but if I come up with a good method of sealing it, it should work.
I was pretty jazzed to see that they fit that close. I will wait for the adapters to arrive before getting too excited though. Want to make sure all of the gasket surfaces are aligned.
I also will need to slightly modify the spacer bracket on the Holley accessory drive kit, to clear the adhe of SBC cover but it's pretty simple.
Thanks for the help.
Old Dec 8, 2014 | 01:06 PM
Mike52's Avatar
Did you find adapters to bolt the SBC center bolt covers to the LS head? If so, where?
Old Dec 8, 2014 | 01:08 PM
JoeNova's Avatar
Restricted User
Why the need to use SBC covers? Ashamed you might be caught running an LS?
Old Dec 8, 2014 | 03:01 PM
1964SS's Avatar
I've seen the adapters for the old school valve covers, but not the old center bolt style. As said above, why are you wanting to do this?
Old Dec 8, 2014 | 09:58 PM
jozw30's Avatar
Not at all, I came up with what I think is a cool idea to dress up my custom build.
How would a pair of valve covers hide the fact that it is an LS anyway?
Old Dec 8, 2014 | 10:12 PM
jozw30's Avatar
No, I bought some long M6 screws and discovered that while the centers are not exact, all 4 screws fit into the holes in the SBC covers without any stress or binding. I will just need to make sure that the seals under the screw heads/nuts work well as they are not dead center in the holes. I think I can make that work.
I purchased a set of the LS to perimeter bolt SBC adapters. I will make the LS center screws into studs instead and use a nut on the SBC cover.
For those really wondering what the heck I'm trying to do, here's a picture of the valve covers I am trying to use.
Original plan was to use these as decorative covers but they just won't sit right without heavy mods.
Old Dec 10, 2014 | 10:12 AM
Mike52's Avatar
joz, I've seen those Olds valve covers adapted to the LS engine! I can't remember where thou! I think it was done by SoCal Speed Shop or Rad Rides by Troy. Here's a pic.
Attached Thumbnails Valve cover adapters-oldsmobile-valve-cover-ls-engine.jpg
Old Dec 10, 2014 | 10:34 AM
jozw30's Avatar
Hey Mike,
Those look cool too! Looks like they used them on top with the coil packs underneath.
Those are the 54-56 style. I have the late forties style covers that are actually cast with SBC mating surface for the hotrodder guys.
I've moved my coil packs to the rear of the heads and want to route the coil wires up and over through the wire loom strip on top.
Thought it would be a cool look and subtle tribute to Olds being as I'm building a 55 88 sedan here. Not planning to use the Oldsmobile sticker on top. Don't want to lose my membership in OCA.....
Old Dec 10, 2014 | 11:02 AM
Mike52's Avatar
Just trying to help. Keep working on a solution and come back here to let us know what you came up with. Good Luck!!
Old Dec 10, 2014 | 11:22 AM
jozw30's Avatar
Appreciate all input Mike. Thanks!
I should have the adapters in the next day or so. I also found some M6 threaded rod locally.
I will post my results good or bad once I have a chance to put it all together.
Old Dec 13, 2014 | 06:13 PM
jozw30's Avatar
Here's a look at what I came up with. Still need to make some spacers inside to prevent over-torquing and am still fiddling around with the wire retainers and placement, but I have plenty of time to sort that out.
Think it looks pretty cool.
Thanks for all of the help!
Old Dec 14, 2014 | 12:40 PM
Mike52's Avatar
I'd say, mission accomplished! Since you are putting this in an Olds, I would use a nice Oldsmobile emblem/decal/sticker on them, perhaps something nostalgic looking like an old Delta 88 emblem(didn't you say it was going into a '55 88?). Your fellow OCA members should remember Olds used GM 'corporate' engines in their cars back in the '80s, you're taking it a few decades further back...LOL.
Old Dec 14, 2014 | 08:19 PM
jozw30's Avatar
Thanks! I will take some time and try to come up with something cool for the wire retainers. If got time. I'm still sorting out what color I want to paint the engine and may not do that until I get the car back for me body shop.
So I've got time. Here's a couple pictures of the car. I just got it off the rotisserie and back onto the chassis for final mockups. It'll go back on the rotisserie at the body shop for him to finish up the bottom side.
Old Dec 14, 2014 | 08:23 PM
jozw30's Avatar
Another shot.
