Ls1 to LQ4
Old Dec 12, 2014 | 06:43 PM
01FireTurd's Avatar
Default Ls1 to LQ4
ive looked around and havnt found these answers .want to swap in a lq4 to a ls1 fbody. I dont have the f body wiring harness, can i use the truck harness? what changes would be needed? also can i use the truck accessories ? i know they stick out 1/2 farther but i dont have the ls1 stuff to swap..... thanks
Old Dec 12, 2014 | 06:58 PM
bclounch's Avatar
Just got done with mine. I believe you have to use the f body wiring harness. What transmission is it bolting up to? May have to tap the back of the block for the transmission. Need an f body flex plate if its a 4l60e. Also may have to relocate the alternator to the bottom of the block, there is only one hole to tap. Will definitely need an fbody oil pan, pickup tube, and windage tray. Other than that it was a fairly straight forward swap.
Also make sure to check on the year of the LQ4 block itself. The 99-00 will not work as it has a different sized crank and won't bolt up to any f body transmission.
Old Dec 12, 2014 | 07:10 PM
01FireTurd's Avatar
ya its a 01 and im going with the 4l80e
Old Dec 12, 2014 | 07:25 PM
bclounch's Avatar
Then you should be good. Your biggest change is going to be swapping in the 4l80e. The motor is no problem. I know the 4l80e's take a bit of modifying to work in an f body
Old Dec 12, 2014 | 09:33 PM
ls1nova71's Avatar
Truck acessories probably won't fit under the hood. Almost positive youll nneed an LS1 intake because the truck intake is taller and will probably hit the hood, but if you use the LS1 intake, it wont work with the truck accessories without some modifications. Your best bet would be to find f body FEAD.
