5.3L Harness rework
Old Dec 14, 2014 | 07:53 AM
Hammy524's Avatar
Default 5.3L Harness rework
Hey guys,
I was planning on having Bill from BP rework my harness but its looking like he isn't going to be doing that service anymore. Anyone else have good luck with another vendor?
thanks
Old Dec 14, 2014 | 08:56 AM
Taxman20's Avatar
lt1swap.com
I just sent Brendan my pcm for a program. Did the harness myself off of his instructions which are actually easy to follow.
Old Dec 14, 2014 | 09:34 AM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Sorry to hear that we suspended the rewires before you were able to place an order. The reason we suspended the rewires is because they are just so time consuming, and with all the "fly by night" guys out there it is almost impossible to charge for the actual time it takes to properly rewire a harness.
Secondly, we also suspended the rewires because of the minor price differences between the rewire and a new harness once you sell your old harness. Here are the numbers for what Im referring to.
Usually you can get this out of these harnesses-
100-150 out of a used Gen III Vortec Harness.
250-400 out of a Camaro/Firebird Harness.
150-200 out of a Gen IV Vortec Harness.
250-400 out of a Gen IV Car Harness.
Our rewire services were priced at $250 and $350 depending on which service you chose.
So if you sell your Gen III Vortec Harness and get say $150 out of it. Put that with the $250 you would have spent for a base rewire and you are at a total of $400.
Our New Base DBC Gen III Engine Harnesses are $500. Just 100-150 more and you can get a new engine harness with a 5ft trunk line, with a grommet installed, GM Color Codes, and the harnesses are routed from the back of the intake forward like the Camaro/Firebird Harnesses.
When you rewire unless you splice 50+ wires you are stuck to the factory lengths and routings. Which for most are less than optimal.
Lastly, on our website and in our ebay store we offer our DIY harness mod kits starting at just $75. These take almost all of the guess work out of rewiring your own harness and come with a labeled fuseblock assembly, OBD II Port Pigtail with plenty of wire, harness tape, and a set of general instructions. (it is impossible to make a specific set of instructions for all of the different applications out there.)
http://www.shop.bp-automotive.com/DI...s-Kits_c10.htm
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Dec 14, 2014 | 09:40 AM
deuce4935's Avatar
If you're still in need of rewire service hit up aknovaman here on the board or wait4meperformance.com
Old Dec 14, 2014 | 02:19 PM
Hammy524's Avatar
Hey Bill,
Thank you for the reply and the information. Didn't think about it that way. Have heard such good things about your work!! More than likely buy one of your new harnesses when I'm ready! Or hopefully I'll win your drawing (ha ha ha) thanks for taking the time I appreciate it!!
Old Dec 14, 2014 | 02:46 PM
Hammy524's Avatar
thanks for all the info!!
