Low mount A/C
Old Jan 3, 2015 | 07:29 PM
S10xGN's Avatar
AlanGrooveconcepts has a vette lowmount FWIW
www.alangrovecomponents.com/LS.htm p.n. 144R A.C.
Wow, that's less than half the $$$ of the S&P kit!
Old Jan 3, 2015 | 08:17 PM
Alongfortheride's Avatar
It does not matter how cheap it is if you can not get lines connected to the compressor
Old Jan 4, 2015 | 01:14 PM
Jimbo1367's Avatar
VA has alot of different lines and adapters available. WIth my lowmount ac compressor, VA offers 90* titefit fittings to clear my subframe. I was starting to get worried about clearing the subfrme until I fount these. (page 74 of their catalog)
366100 #6 TiteFit 90 0 A/C Fitting
366101 #8 TiteFit 90 0 A/C Fitting
366102 #10 TiteFit 90 0 A/C Fitting
Old Jan 4, 2015 | 01:52 PM
I saw those fittings. I am curious to see what they say works. I do believe there will not be enough room for those to fit
Old Jan 4, 2015 | 02:11 PM
cmac06's Avatar
I have the Alan Grove fittings and there is very little room left to get any fittings in for AC, so I'm switching to the CBM fittings for some additional clearance.
I tried both styles of compressor heads and they both have unique issues due to how my headers are made.
Old Jan 4, 2015 | 04:00 PM
Old Jan 4, 2015 | 04:01 PM
Old Jan 4, 2015 | 04:02 PM
I can see how I can make a little different upper mount and make it work I was just curious what they have done in the past. There lower mount is nice
Old Jan 4, 2015 | 09:54 PM
kwhizz's Avatar
I've got plenty of room
Ken[/QUOTE]
Old Jan 5, 2015 | 03:01 AM
cmac06's Avatar
Ken
[/QUOTE]
What compressor is that? I have a Sanden 7176, will that work?
Old Jan 5, 2015 | 07:46 AM
I do believe it is and sd7
Old Jan 5, 2015 | 08:25 AM
  #32
rockytopper's Avatar
subbed for future use
Old Jan 5, 2015 | 04:24 PM
  #33
kwhizz's Avatar
SD 7 Sanden...............
Ken
Old Jan 19, 2015 | 01:03 AM
  #34
cmac06's Avatar
Finally got mine mounted. I was able to get a compressor off a 99 Geo Metro with a 4 rib pulley. The compressor is a quite a bit shorter than the SD5. I'll be getting rid of a set of Dirty Dingo slider mounts next. I think I can go back to standard mounts without notching the frame on a Chevelle which I've been trying to avoid.
I'll be going with the DD Muscle Mounts, since my mounts have already been located 2 inches back, I should be able to move the mounts all the way back and have plenty of room behind the compressor.
Old Jan 23, 2015 | 07:49 PM
  #35
cmac06's Avatar
If anyone cares, don't try the tite-fit fittings from VA, no way it'll work. Maybe someone will provide a more optimal location for the upper mount or a fitting that can squeeze in there.
Old Jan 24, 2015 | 02:17 PM
  #36
1bigoldman's Avatar
Ken
[/QUOTE]
kwhizz, what adapter plates and motor mounts are you using?
Thank you!
Old Jan 24, 2015 | 06:41 PM
  #37
john 67's Avatar
Made these a while ago, uses main pulley and corvette spacing . I have templates if needed.
Old Jan 25, 2015 | 08:16 PM
  #38
kwhizz's Avatar
With the stock GM frame mounts and the Dirty Dingo sliders.......I didn't have the room for the A/C compressor.......I made my own mounts to get the room I needed.......Here are some pic's to show how it worked out....Start to finish......Again....this is for LSA applications where the compressor can't go up top......
Old Jan 26, 2015 | 08:41 AM
  #39
1bigoldman's Avatar
john 67 thanks for the pic's. I have seen your setup before and I like it. I'm not sure if it would work with my compressor. You have the Sanden 508 I've got the SD-7B10 unit.
kwhizz nice machine work on your setup. Originally I was going to run a SBC in my car when I ordered my TCI clip. I really hate to cut those nice TIG welded frame stands off.
I also find it interesting that on both of your blocks you have a rear/third bolt boss on your block for the lower bracket. My motor is an '04 Vette and FED and does not have that rear most hole or even a boss there.
I really want to have the motor in the 1" setback from the "STD SBC" location and down low. I have the room up top I just don't like the look of the top mount brackets. It's just me being hard headed.
Old Jan 26, 2015 | 10:44 PM
  #40
cwylie's Avatar
Well after modifying this Alan Grove mount to fit an Sanden SD7 I think I am just going to high mount my a/c compressor after all so its up for sale. I intended to use it with this manifold. I cant see why it would not work.
http://nostalgicac.com/fittings-hose...r-adapter.html
https://ls1tech.com/forums/parts-cla...sor-mount.html
[/B]
