LC9 into a Porsche 944
I'm looking at swapping out the 4cyl in my 944 with a V8, specifically an LC9. Since I'm totally new to this engine, but swapping in general, I have a few questions.
Since it's originally a AFM/E85/Auto engine, is it possible to make it a non-AFM/E85/Manual?
My brain is all crazy right now and I'm not finding the answers that I need online. I don't see why it wouldn't work, but I've been wrong many times before.
Thanks!
I was mostly wondering if I can delete that and keep the e85 and swap it to a manual. I might have to check out a truck forum, I suppose.
I haven't figured it out for sure, but I've drawn the conclusion that the T-56 will mate up to it. I just need figure out the bell housing thing. Not sure if the LS1 and LS2 bell housings are the same, but the LS2 seems to be the choice if they aren't.
Still looking around though.
If you get an LS2 GTO bellhousing, you'll need a starter for a GTO. If you get an LS1 F-Body bellhousing, you'll need an F-Body starter.
Tipsy
Summit Racing® Active Fuel Management Delete Combos 09-0026
http://www.summitracing.com/parts/cm...commendedparts
I can't offer expertise with doing the deletes and you still need to get the AFM portion of the ECU deactivated. Also, Black Bear Performance can do the AFM deactivation so an AFM motor always runs in V8.
Then there's the VVT too, which I don't know about. Maybe your cam vendor could elaborate.
Edit: actually it was a l9h 6.2L. But keeping the VVT is still a good option when tuned well. AFM has gotta go though.
