New LS engine - to paint or not to paint?
Old Jan 2, 2015 | 11:08 AM
old66tiger's Avatar
Default New LS engine - to paint or not to paint?
So...new LS3,and contemplating painting it or leaving it raw. Was thinking of clear coating but I can not find any clear that is guaranteed not to yellow. If I decide top paint it, where do you start and stop? The old school Pontiacs were easy to paint because there was definite start and stop points on the block. Thoughts?
Thanks..
Old Jan 2, 2015 | 01:20 PM
Fierofly's Avatar
I Say clean off all the casting marks with a grinder, mine had some on the heads that would cut your fingers, Clean the whole thing with lacquer thinner, Paint with a good high heat ceramic paint.
Old Jan 2, 2015 | 05:45 PM
79LS1FOX's Avatar
Default paint or not
If its cast iron paint it otherwise leave it alone. JMO
Old Jan 3, 2015 | 11:19 AM
6speediroc's Avatar
I used KBS motor coated on a cast block and andvery happy with it.
http://www.kbs-coatings.com/Motor-Coater.html
Old Jan 3, 2015 | 12:49 PM
Fry_'s Avatar
Eastwoods 2k hi-temp matte clear would probably work if you just want to keep the block from corroding.
Old Jan 4, 2015 | 08:00 PM
STEVE PWC's Avatar
I Por15 mine. reduced it and sprayed it there a gun. Looks really nice.
Old Jan 5, 2015 | 09:45 PM
kj598bbc's Avatar
I paint every swap/install I do. I've already painted my LM7 covers corporate GM Cadillac blue to match the paint from the original 425, so I say paint ! At least the short block and maybe match the valve covers.
Old Jan 6, 2015 | 09:00 AM
Fierofly's Avatar
Ceramic Spray cans.
Old Jan 7, 2015 | 07:09 PM
flipt86's Avatar
Goodson's Last Blast Hi-Temp paint has been great for me to work with so far. Dry's quick and covers amazingly well... Easy to use with no runs.
