2000 suburban into 1940 chev panel van
Also keep in mind that you have a truck intake and switching to a car intake is not as simple as just switching the intake, The car intakes throttle body sits lower so it will run into the truck water pump outlet and changing to the car water pump also changes the accessory pulley spacing so you would need to change everything or modify it to make it work.
1" setback mounts will put the LS close to the original trans/engine mating surface location.
You can keep the trans and mechanical clutch. Info here :
https://ls1tech.com/forums/conversio...-ls-motor.html
LT1wasp.com is a great resource for re-doing your own harness. Also does reflash for $75, I think.
If the motor is low mileage, don't change a thing, don't touch it! Keep the intake, cam, etc. These motors run great and are leak free a long time.
Intank pumps may not be that much quieter, but tend to be more reliable too. Immersed in fuel keeps them cool.
AC will depend on the compressor you use and spacing. But Holley makes brackets for the R4 and sanden compressor in truck, f body, and vette spacing.
http://www.compcams.com/Company/CC/c...csid=1089&sb=2
will work great for you , dont forget springs at the same time .
A fuel injected 5.3 ls motor,," lm7" I suppose is a great motor in an of itself no cam neaded , you will be putting a free flowing exhaust behind it im guessing and that alone will increase the power and torque ,,, let alone "drivability" far beyond what the 283 did ,,, Ill bet no one complained about the old suburban not having power ,,, and it probably outweighed the panel you are putting it in by 2000 pounds . The torque curve comparison of a carbed 283 compared to a fuel injected 5.3 ls is a joke the 283 is like a hill up and down ,, while the ls is fairly flat and about 100 foot pounds higher .
