impala 1996 swap to ls1
Old Jan 12, 2015 | 12:09 AM
Black Impala ss's Avatar
Default impala 1996 swap to ls1
hi,
I have 1996 impala swap to ls1 , it's work and start but my problem with temp when I unlock the switch of the car the temp go up to high even the car not start & when the car start the temp go to max temp but there is no heat the engin and the water cold , I mean no real problem with heat but the problem with heat temp . it's because the sensor ? or the way of wired ? how I can make it read correct temp ?
Old Jan 13, 2015 | 04:35 AM
any hint or advise ?
Old Jan 14, 2015 | 02:22 PM
N20zuki's Avatar
If your using the stock gauges, you should be using the stock LT1 sending unit.
