ls1 c3 vette
Old Jan 21, 2015 | 08:15 AM
fastlt1's Avatar
Default ls1 c3 vette
Anyone put a ls1 out of 99 camaro in a 1980 c3 vette. How big of pain any special parts needed. Thanks
Old Jan 21, 2015 | 09:38 AM
Envy's Avatar
Here ya go.
In 30 seconds of searching, it looks like you'll need to do your homework on your oil pan clearance, exhaust and accessory drives, looks like either Vette, F-body, or aftermarket are your options... Things like motor mounts should be bolt-on issues, transmission should stay in same spot, so unless you change the transmission, you shouldn't have to adjust the trans mount or driveshaft, you'd just need an adapter to bolt on the older style SBC trans to the LS engine. Also you're going to need the PCM reflashed, a modified harness, and a high pressure fuel pump to achieve the psi required to run fuel injection.
Good luck.
Old Jan 21, 2015 | 10:22 AM
garys 68's Avatar
Go to the corvetteforum C3 section, about 2 dozen builds.
