need helpwith new engine harness 4 wire hookup
Old Feb 14, 2015 | 07:17 PM
lsx_production's Avatar
Default need helpwith new engine harness 4 wire hookup
93 mustang with 5.3 dbc swap with t56
Few questions. Where did you guys do your hookup for the fuel pump and switched ignition wires? I see the tach, speedo, power, and ground wires will be easy to figure out without a problem but I even bought a Haynes manual and the wiring diagrams in the back are garbage so any help on that would be appreciated.
Also, There are two connectors that run to the transmission but there are spots for three on the transmission itself. Do I need this connector? it looks like its for the reverse lockout which I obviously need. please help!!
Old Feb 14, 2015 | 07:20 PM
sowbelle's Avatar
lt1swap.com
Old Feb 14, 2015 | 07:41 PM
what about it? didyou even read my post
Old Feb 14, 2015 | 07:55 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I can't help you on the switched ignition and fuel pump connections for the fox body, but I can help with a couple other things.
Instead of the Haynes manual, you can try alldatadiy.com. However, with it being a 93 the diagrams might not be as good.
On the transmission you will have two solenoids that look exactly alike. The farthest one to the rear is the reverse lockout. It's close to the vss at the rear of the T56.
I hope this helps!
Bill
Old Feb 14, 2015 | 08:12 PM
I actually bought my harness from you guys haha. so what are all the other connections on the tranny for? and what do the two that you guys have on your harness connect to?
Old Feb 14, 2015 | 10:37 PM
LS1Tech Sponsor
They are the reverse lockout and vss connections.
The third connection on the transmission is the skip shift solenoid and it won't be utilized.
Thanks for your business!!
Bill
Old Feb 15, 2015 | 11:27 PM
Bill
absolutely! even left feedback. Just one question though. the VSS connector on my t56 has a pigtail and is a larger 3 pin. the one on the harness I purchased from you guys is a small 2 pin. How can I fix this or can I roll without it? thanks!
oh! also I noticed the oil pressure sensor is not used either. is there a reason for that?
Old Feb 16, 2015 | 09:44 PM
bumps
Old Feb 17, 2015 | 04:58 PM
bumps
Old Feb 17, 2015 | 07:08 PM
Hawk465's Avatar
Have you considered giving Bill at BP Automotive a call? He's been pretty easy to reach on the phone and always helpful when i was ordering my harness.
Old Feb 17, 2015 | 09:34 PM
yes. this isn't really harness related. its vehicle related
Old Feb 18, 2015 | 11:00 AM
76larkman's Avatar
call the wiring guy but have you checked to see if there a 2 prong vss connector that will work.
Old Feb 18, 2015 | 12:20 PM
1964SS's Avatar
What T56 do you have? Most I've seen are 2 pin. You can buy a 2 pin VSS from your local auto store for about $20
