foxbody wont turn over
I did a auto the manual conversion and deleted the starter solenoid.
the wire from the ignition that comes the firewall (I) wire is directly connected to the wire that is on the solenoid (S). I can manually jump the two posts on the starter and it will turn over no problem but turning the key will not start the vehicle. Any information would be greatly valued. thank a lot.
They usually just close either a positive or negative circuit to allow the starter to engage. This is what tells the starter circuit the vehicle is in park or neutral to avoid running someone over by starting it in gear.
You did say you went from automatic to manual? If that is what you have done, then you need to add a clutch safety switch somehow. That will only allow you to engage the starter if the clutch is pressed to the floor. Again, for safety. You will need to contact someone more familiar with your vehicles wiring to get it to work properly and look factory.
Best of luck.
