5.3 running with only 4 coil packs?
Most likely running on an aftermarket injection system in wasted spark mode. Waste spark firing means that two spark plugs are fired at one time. When a coil fires two cylinders, one is on the compression stroke and one is on the exhaust stroke.
This is how the Cadillac Northstar and many others work.
