DBW Throttle Problem in LS2 Swap
We have swapped and LS2 and manual transmission from a 2006 GTO into a 2nd Gen Camaro.
Everything is now installed and engine does fire up, VATS and other stuff disabled and no codes. Using the original wiring and ECM
The issue is that while in ignition, engine stopped, the blade on the throttle body opens completely, but while the engine is running it opens very little.
the throttle readings while engine stopped goes from 20 whitout touching the pedal, to 88 while fully depressed. When the engine is running, it stops in 40. and although the start-up reading is 20, the engine idles perfectly.
I'm thinking about a ground or other electrical issue or something in the computer blocking the throttle when the engine running, maybe something like a "limp" mode or still anti theft related.
any ideas welcome.
Ok, the only thing "not from the car" is the ECM, a local electrician killed it so I got one from a 05 Monte Carlo. We were lucky enough to be able to read the original ECM before it was killed and did a "write complete" of those settings into the Monte Carlo unit.
APP (gas pedal) = GM.APP (this will show 100% as WOT when logged)
TB (what the TB is at) = GM.ETCTP (this will only show ~86% as WOT when logged)
I prefer to use GM.ETCTP when tuning, as it shows if the computer closes the TB. While APP will remain the same.
I'm not sure what you mean when you talk about it being 40.
any ideas welcome.
Bill
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Tipsy
A friend brought another PCM also from a GTO, also vats disabled and the response was the same.
I've read somewhere that you need to pair the pcm to the engine vin before it runs so it was bit of a surprise both did work. I tried to change the VIN into my PCM but it was not possible, but I know the O.S. From the old pcm is loaded as before we load it the engine didn't start.
I finally decided to skip the tuner and start doing this by myself and ordered a copy of HP Tuners.
Thanks for the information on the throttle.
When I say 40 I mean the reading instead of going from 20 to 88, as it does when the engine is not running, only goes from 20 to 40 when the engine is running. You can actually see the blade opening just a little bit
The engine is working great now
What I finally did was to forget about the current ECM setup (not done by me), and started fresh. Downloaded a stock tune from the HP Tuners database, and change the needed settings for the swap (disable VATS, EVAP, ABS, Sensors, etc, etc, etc).
Did a "write-complete" of this new file into my ECM and it worked like a charm. Now, it's time to start the engine tune, so start driving it and logging to make a better calibration for my setup.
The sad part is that using a file from the HP Tuners repository takes credits, but I'm still very happy about the results.
This is the second fire up with the new file, If you dont' understand spanish I just say it's the result of 5 minutes of messing with HP Tuners.
https://www.facebook.com/video.php?v...73370799778590
Tipsy
My friend hasn't still used that ECM as the car is being restored so we will know when he plugs it.
