ls3 swap won't start! Pulling my hair out!
Sorry, if I turn the key on and prime the pump it will fire for maybe a second not even. If I don't turn the key off and try cranking again it starts to backfire a little bit threw the intake. But if I turn the key off and prime the pump again it will start for not even a second and I have to keep cycling the key for it not to backfire and fire up.
When I straight wire the fuel pump it will keep firing and stalling with no backfiring. The harness has a ignition wire and one main power wire which both have good power. I'm running the ignition switch wire to the same wire I had hooked up to the msd 6012 when it was carb'd.
#32
its gotta be that saab pedal. I think- unless you change a couple wires on the saab pedal, from what I remember- the ctsv, corvette and 1 one of the monte carlo or impala are the only ones that will work with the gmpp harness...
pmed you~~~~
pmed you~~~~
#34
I have similar issues with my ls1 swap. Did you replace the cam by any chance and might throw the timing off? How about the crank sensor? Is it new? If you have good fuel and good sparks, you might want to check that issues I mentioned above.
#36
Thanks for all the quick responses guys but a buddy found the problem. Bad injectors. He stopped by and checked everything out and some aren't clicking he said. Just buy tapping on a few of them the engine would run longer but soon die. I bought them used and have no clue how long they have sat around for. I'm gonna pick up some new ones prolly this week and try again but he swears it's the injectors.
#39
