Fans running constantly with PSI harness
Ls3 running a Psi harness and ecm, and the output to each fan almost immediately after the car starts supplies negative regardless of engine temp. The odd thing is, when a Power Probe is connected to the fan trigger wires from the ecm, it's not a consistent negative output, but broken up....kind of like -----.-..-..-...-------.-.--. It is enough to energize the relay and run the fans.
