HELP!!! 700r4 flywheel hole issues
Another concern....I an not sure about a transmission from '95, but the truck "LS" motors, (4.8, 5.3, 6.0 and 6.2) have a different flywheel/converter than the true "car" LS motors (LS1, LS2, LS3, etc. I would bet that your converter isn't lining up because you are mixing a truck motor and a car transmission. I could be wrong though.
http://www.ebay.com/itm/New-Speedway-LS-Crank-to-GM-TH350-400-Converter-Sleeve-Adapter-4mm-Centerplate-/131442165621?hash=item1e9a904775&vxp=mtr
if its flat you need this
http://www.ebay.com/itm/700R4-Early-4L60E-Adapter-to-install-a-LS1-motor-/130944454153?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7ce5ce09&vxp=mtr
you also need to elongate the converter bolt holes toward the center of the flexplate approximately 1/8 of an inch ,,, a rattail file works well for this purpose , or a dremel tool
