Do LS1s have water pump issues?
I have wondered if the water pump might be weak since it will cool down if the engine is revved up. Now I am seeing 2 and 3 pass radiators and wonder if they work well. I just don't think it is the radiator but have to wonder about the pump since it does better just setting with some RPM. Do LS1s have issues with water pumps?
Also check your radiator seals, etc...make sure air flows through the radiator, not around it.
You don't NEED a dual pass radiator to run these engines or anything fancy in the cooling department. All that is necessary is a solid cooling system with good airflow. All that is needed is a quality radiator, no leaks or air pockets in the cooling system and a quality electric fan. Since you are talking temps at idle while sitting, the electric fan is all you get. As mentioned by Gary's 68, cheap fans are no good and good fans aren't cheap. I've seen people waste money too many times on parts store fans that hardly move enough air to disturb a dry leaf. I prefer OEM style fans because I know they pull enough air. Good fans cost more AND pull a lot of amps. If a fan doesn't need a 30 or 40 amp fuse (unless it's PWM) it's probably not going to cool your engine at idle in the summer no matter what radiator.
I'm also in KC if you want to talk in person.
Draws 25 amps at steady state.
Keeps engine just at thermostat opening point 185F with AC on. I've only tested at 88F ambient. Can't imagine seeing over 100F ever. Even if engine temp went up by 12 I'd be fine with that.
I'd try a better fan. Check how much yours draws.
Doug
If you're going to have an aneurysm about overheating:
1: get rid of the 180 stat. That prevents nothing with regard to overheating. It sets minimum temp only. It does however, allow the engine to fluctuate temp more, get worse mileage, allow more carbon buildup, and shed heat that should be used for power. Further, a narrower range of temps gives the tune a narrower range to be right. Psychologically, a gauge that wavers is going to drive you nuts. A stable temp range is peaceful in comparison.
2: Get a mechanical fan. My DD is SBC (for now) and I have never wondered or worried whether it's working. Clutch going bad? I knew about it and it never let things overheat. A fan clutch that fails is noisy. An elec. fan that fails at the wrong time is expensive with collateral damage. Yes, I drive in 120deg temps. I switched from multiple v-belts to single serpentine and kept the mech. fan.
But my real question is, since im in the KC area,how have I never seen this car before???
If you need the LS1 intake for hood clearance, you can use a snake head intake elbow to clear the fan. I ended up making one out of fiberglass.
The guy saying to run a mechanical fan...no. Don't do that. Run an OEM electric fan. Or pay the big bucks for an aftermarket fan that actually works. The cheap fans are simply rubbish.
Novas Forever, you really need to scan the car and see what the PCM thinks is happening and why. If you don't have access to the tools, I do. A 160 or 180 stat in these engines is completely worthless without the tune to compensate for it.
Do you have your fan setup as a pusher(bumper side of rad) or a puller(engine side of radiator)?
I would love to have a mechanical fan but F-body water pumps are not set up for them and there is no way there is enough room anyway. I have actually seen it get up to 250 in traffic but go down to 185 in the open. I understand that an all aluminum engine is different than a cast iron one and will adjust my thinking for it.
You KC folks have not seen my car because I usually stay around Lee's Summit. I go to Johnny Ray's quite a bit. You can look up on older video of it on YouTube. search for 1962 Chevy II Nova. I have been to Heartland over by Joe's Crab Shack but it is like my car is invisible. It is unassuming but is much more than just an old black Nova. It is not a painted up POS. I will get over there more often this summer so maybe you will see it there. Look for a black Nova that looks like the paint is 12 inches deep with red interior and an automatic that looks like a stock shifter in an SS.
When I put the LS1 in my car 10 years ago it was unusual and quite a unusual. I could not have done it without the help of people on here and at Steves Nova Site. Be glad that there is help for you guys now.
I will come back and let everyone know how the bigger fan works out.
also. I've been to Johnny Ray's and Jackson drive quite a bit, but just don't recall seeing this car.
