Harness, MicroSquirt vs. Psi?
Old Apr 8, 2015 | 06:09 AM
fstfox87's Avatar
Default Harness, MicroSquirt vs. Psi?
Ok I'm building a 87' fox LM7 with GT45 turbo. Iv heard great things about both harnesses but has anyone used the MicroSquirt plug and play harness?
http://www.efisource.com/shop/ls1-24...-play-harness/
Iv searched here and all I can find is people just using the ecu.
I also found the painless harness on sale too http://m.summitracing.com/parts/prf-...2SrxoCd7zw_wcB
Old Apr 8, 2015 | 08:12 AM
aknovaman's Avatar
I personally have had 2 Painless harnesses with the wires in the wrong PCM connector positions. Nothing wrong with the PNP Micro as you can block off the factory IAC and passage then use the FIDLE wire to run a Ford taurus fast idle solenoid inseries with one of the large vacuum ports on your intake.
