Hooker Fbody Swap, BAD EXPERIENCE
I'm pissed at FAST right now. I've got a efi system that arrived new with bad wiring and a faulty map sensor.I'm out 10 + hours of troubleshooting and I've got a track event this weekend. It didn't even occur to me to ding them for my labor, as I've already factored Murphys Law into my build. Not worth the bother and high blood pressure. Yes, i will try to stick them for parts. If that fails, reputational damage will be next on my list. After that, I'm done. I can't keep focusing on a grudge without it costing me elsewhere.
Life is too short.
Agreed. I've made my point on this forum already and will continue to share my stories with others. They can decide on their own.
My honest opinion. If this if going to be you response for every part you buy that doesnt fit 100% correctly on the first shot you should give up on this build now. Its only going to get worse the more parts you bolt on.
Other than that difference, the parts fit both vehicles. The crossmember includes two angle brackets that are used to attach the crossmember to the side wall of the subframe when there is an alignment disparity between your trans mount and the top holes in the frame; it's defined on page 3 of the crossmember instructions in step #5. You chose to do it another way instead of asking to return the product(s) if you didn't like the installation method/requirements as mentioned by another previous poster.
Even after that, Holley offered to give you a full refund for the parts and you think that is somehow underhanded?
There is a 71 Firebird similar to yours being assembled in the lab right now using the same engine brackets and crossmember as you have and aside from the revision to the hole drilling operation for the mounts everything bolted right in due to the fact that the crossmember instructions were followed as written.
You're obviously not satisfied with the parts, so why not send them back?
Incorrect again Todd. See below. My vehicle did have the proper holes in the subframe and was installed according to the instructions. The angle brackets are used in the instructions only if you don't have the subframe with the prepunched holes. I chose to install it per instructions, which by the way, required removal of the subframe and changing it on the fly is not easy.
"5. If your vehicle is an earlier model with pre-punched factory holes present in the subframe at the location of the crossmember, use
the holes to attach the crossmember with the supplied nuts and bolts and skip to step 6 now. If your vehicle is a later model that
does not have corresponding holes present in the frame in the area of the crossmember, proceed to step A below."
I believe Holley has offered you a reasonable solution.
Frankly your time is worth zero. If you don't want your time to be worth zero, don't participate in a hobby.
FACT:
Holley sold a product with improper marketing that doesn't fit. This has been acknowledged.
OPINION:
I would surmise there are many other products in their arsenal with the same issues.
FACT:
There are cheaper options out there in which you can anticipate a custom install as that is how THOSE products are advertised.
OPINION:
If I had to do it again I would not have let someone persuade me to use Holley for the ease and engineering.
Everyone else its up to you. Good luck with your builds all!
I still used all their components but had to mark where the mounts had to be drilled. I still feel they make excellent products despite this issue. It looks like this may be resolved soon...I feel sooner if they would've looked into it when I brought it up.
The biggest pain in the *** was dropping the motor in a few times trying not scratch anything.
I talked about it here in Post #42:
http://transamcountry.com/community/...topic=68544.40
The world of car building is not an exact science. It seems to me that Holley is willing to give you your money back for their product. Your time on is on you as you decided to modify what was working in the beginning.
As a further update Mr Shane Wickerly the VP of engineering contacted me a very professionally apologized. They are working with me to make it right and for that I am thankful.
You said your peace and i would be unhappy also but dont waste more time or money you made the parts work just move on life is to short!
Good luck either way~!
When making parts for 40 year old cars, there are a ton of issues to deal with. Sometimes you find out that GM (or other makers) did goofy things. The 1st ten F-body subframes were drilled for both Chevrolet and Pontiac engine stands. The same was true for 64-72 GM a-bodies. My 1970 GTO's front crossmember looked like Swiss cheese from the factory because all the different bolt patterns for the various engine clones were there. So it wasn't a big stretch to think that later F-bodies had all the holes there regardless of the clone variety. Clearly that was not the case, but Holley is fixing it, which is more than can be said for a lot of other aftermarket companies.
Andrew
