Belt line question
Old Apr 30, 2015 | 01:14 PM
t-town's Avatar
Default Belt line question
I am using the GM low mount alternator bracket p/n 12563327 which I think is from a F body v-8 application. I have two questions for you guys.
With using the low mount alternator bracket will the harmonic balancer and water pump pulleys from my donor truck motor still work? Or am I going to have to swap over to the F body balancer and water pump to retain a proper belt line. Next, When drilling out the blank boss on the block for the new alternator bracket, how deep should I drill this hole?
Thanks for the help, Tony
Old Apr 30, 2015 | 03:17 PM
1964SS's Avatar
You will need to change the water pump and balancer to line up with the F body alternator location. The truck setups are further out then the F body setup.
Old May 5, 2015 | 03:23 PM
t-town's Avatar
Thanks!
