68 Camaro 327/m20 to lq4/lsa/t56
Old 12-19-2015, 09:40 AM
  #41
DT69cam's Avatar
Nice Project Jason. I'm just in the tear down stages of my LS3 conversion into a 69 Camaro convertible. Why the switch from Tanks Inc ?? I was planning on going this route due to the cheaper cost. I don't think the total was 500 out the door.
Old 12-19-2015, 12:55 PM
  #42
Blue89Bird's Avatar
Being blown I need something that adjusts based on boost. By the time I figure in the price of a boost referenced regulator an extra fuel line etc it's not much more expensive. I'm still not 100%
Old 12-19-2015, 06:42 PM
  #43
Blue89Bird's Avatar
Going to go with...
Chevy orange block
Black hammer tone front cover, accessory drive brackets
Polished fabricated valve covers
68 Camaro 327/m20 to lq4/lsa/t56-wafjjfx.jpg
68 Camaro 327/m20 to lq4/lsa/t56-gqwzhzh.jpg
Old 12-20-2015, 06:35 AM
  #44
DT69cam's Avatar
Very very nice.
Old 12-23-2015, 07:05 PM
  #45
Blue89Bird's Avatar
Accesory brackets came today (lsxconcepts) so I couldn't help but slap them on and the blower to take a look.
68 Camaro 327/m20 to lq4/lsa/t56-08ks4h1.jpg
68 Camaro 327/m20 to lq4/lsa/t56-dq9ldib.jpg
Water pump and ps pump will be here end of week and I'm picking up the balancer this weekend.
Old 12-26-2015, 11:16 PM
  #46
camarodude87's Avatar
So witht eh DBW swa with the pedal etc. How much that run you. Im debating on doing a LSA swap myself.
Old 12-27-2015, 06:06 AM
  #47
Blue89Bird's Avatar
I'm not doing dbw.
Old 12-27-2015, 11:18 AM
  #48
what heads are you running?
Old 12-27-2015, 12:48 PM
  #49
Blue89Bird's Avatar
Lsa heads
Old 12-29-2015, 09:53 AM
  #50
Blue89Bird's Avatar
Finally got all of my accessories in. Waiting for the passenger side tensioner and bolts as well as the belts which should be here tomorrow and then the FEAD is done.
68 Camaro 327/m20 to lq4/lsa/t56-0apb235.jpg
Found out this blower came with a special offset pulley that allows the use of fbody accessories so I had to pull the snout to have that removed. I've got someone buying that this weekend and then I'm just going to have a stock one pressed on for now.
Next up parts wise is the holley/hooker swap kit and my yet to be decided fuel system. As soon as all of that comes in I'll be ready to start yanking out all of the old stuff and we'll really start moving.
Old 02-21-2016, 07:32 PM
  #51
Blue89Bird's Avatar
Getting there.
Holley valve covers, new coils, finally got my crank pulley and finished the accesories.
These holley valve covers are awfully pretty.
68 Camaro 327/m20 to lq4/lsa/t56-vy9odps.jpg
68 Camaro 327/m20 to lq4/lsa/t56-hdmao0a.jpg
68 Camaro 327/m20 to lq4/lsa/t56-exw5hia.jpg
Getting the crank pulley on was a bitch despite heating it a while. Still have a small gap on the crank snout. My buddy told me there's supposed to be 2.4-4.5mm which im well within but I always assumed it had to be flush. Drill is charging and I'll hopefully pin it tonight if I grow some *****.
Old 02-25-2016, 06:27 AM
  #52
Blue89Bird's Avatar
So in order to use the holley swap kit you need to switch to the late style clamshell motor mounts.
I got these:
68 Camaro 327/m20 to lq4/lsa/t56-42xitr2.png
Along with these to use for the cross bolts:
But their too damn short. I triple checked the part numbers and they seem to be right. Guess I'll have to call arp tomorrow
Old 02-26-2016, 02:41 PM
  #53
Blue89Bird's Avatar
talked to arp...they were basically like i dunno....find it hard to believe I'm the only one that's run into this since its a super common application. The bolts are 3.75" and need to be about 1" longer. Said they don't even offer anything longer than this as it's their longest bolt.
I guess these go back and off to the hardware store I go.
Holley 302-2 and motor mount adapters will be here tomorrow. In the meanwhile I'm standing here making car noises
Old 02-27-2016, 10:12 AM
  #54
Blue89Bird's Avatar
Just as im walking out the door.
68 Camaro 327/m20 to lq4/lsa/t56-j54qpr0.jpg
Guess I'll be doing some wrenching this evening.
Old 03-01-2016, 02:22 PM
  #55
Blue89Bird's Avatar
68 Camaro 327/m20 to lq4/lsa/t56-j8bg25z.jpg
68 Camaro 327/m20 to lq4/lsa/t56-3w1yvf5.jpg
68 Camaro 327/m20 to lq4/lsa/t56-ehhurqg.jpg
This just got here
68 Camaro 327/m20 to lq4/lsa/t56-vtlxjwf.jpg
Old 03-02-2016, 02:23 PM
  #56
Blue89Bird's Avatar
68 Camaro 327/m20 to lq4/lsa/t56-6bxs6oo.jpg
68 Camaro 327/m20 to lq4/lsa/t56-3tp77w6.jpg
Should be in business once the clutch, hydraulics and pilot bearing get here.
Had to spread the damn frame rails about 1/2" to get it to mount. Must have warped some when it was baked/powdered.
Old 03-02-2016, 07:07 PM
  #57
Centerforce's Avatar
Solid progress so far! What setup did you go with?
Old 03-03-2016, 05:21 AM
  #58
Blue89Bird's Avatar
Just a factory ls7 setup. Should be fine for the street since I'm on street tires and it may see the racetrack once a year.
Old 03-06-2016, 10:19 AM
  #59
Blue89Bird's Avatar
Pinned the crank. Not sure why I was so afraid and kept putting this off. Took me under 5 minutes.
68 Camaro 327/m20 to lq4/lsa/t56-ppmmalk.jpg
68 Camaro 327/m20 to lq4/lsa/t56-wbamdpx.jpg
68 Camaro 327/m20 to lq4/lsa/t56-owxupbr.jpg
Hopefully clutch is here soon.
Old 03-06-2016, 01:53 PM
  #60
Blue89Bird's Avatar
Wife just caught me cleaning my t56 bellhousing in the stationary tub with a Brillo pad. She's not too happy. Plus side is I think I've got permission to buy a parts washer.
Bellhousing cleaned and painted.
68 Camaro 327/m20 to lq4/lsa/t56-xwx4qgu.jpg
Quick Reply: 68 Camaro 327/m20 to lq4/lsa/t56
