Fuse block for thrifty swappers
So I found this out by accident when I was looking for something to house relays in for a project I'm working on and figured I would throw this out there for people like myself who like to save money. You can plug in up to 8 relays with ten fuses or up to 34 fuses by themselves! The Metri-pack 280 terminals work perfect for the fuses and relays, same thing you use for the Bussmann fuse and relay panel. The only draw backs I can think of would be it won't be weather tight and not super easy to mount. This is connector C1 of the underhood fuse block usually left on the wiring harness on pull outs.
These have 60 slots and are easy to mount:
http://www.waytekwire.com/item/45990...se-For-Sealed/
They use the same Metri-Pack 280 terminals.
Andrew
Andrew
