LQ9 and LS1
Old Jul 17, 2015 | 03:31 PM
blueracer15's Avatar
Default LQ9 and LS1
just picked up a lq9 from a silverado SS
What parts can just swap over?
From my research all ls1 accessories onto the lq9 water pump ect
what about oil pan?
can i just swap the oil pan over or do i need other parts before i begin on this?
also how do l92 heads work according to pushrod lengths and ect because there are so many different pushrods i see with minimal differences will this head constitute a change or can stock pushrods be used
Old Jul 17, 2015 | 05:48 PM
sierravmax's Avatar
Ls1 accessories will swap over. You have to drill and tap a hole for alternator if you are using Ls1 fbody accessories. Oil pan will swap over. Make sure to swap dipstick, oil pick up and windage tray also.
Old Jul 17, 2015 | 10:56 PM
Thanks , anyone have any other solid info
Old Jul 18, 2015 | 09:25 AM
bczee's Avatar
You also need to swap over the pulley/balancer as there is a difference of .75" in spacing.
Old Jul 19, 2015 | 07:30 PM
Awesome and will ls3 heads for this block ?
Old Jul 20, 2015 | 09:08 AM
Will push rod lengths change with ls3 heads ?
Old Jul 23, 2015 | 04:25 PM
when looking for aftermarket heads it seems that the l92 and ls3 are the same so could i use either or?
Old Jul 23, 2015 | 09:53 PM
BadgeZ28's Avatar
LS1 has the crank sensor on the side of the pan toward the back.
Old Jul 23, 2015 | 10:01 PM
sierravmax's Avatar
Both ls1 and lq4/lq9 have a crank sensor on the side of the block towards the back behind the starter.
Old Aug 2, 2015 | 06:15 PM
I wanted to swap to car accessories i have seen a lot of people do hybrid things like take the pulley of the truck and put it onto the car water pump
is there an actual list of all the parts i would need to get car accesories onto the LQ?
All f body
Water Pump
idler
tensioner
crank pulley
alternator and bracket
Old Aug 6, 2015 | 02:41 PM
everyone seems to upgrade to ls2 timing chain is that a recommendation for boosted applications?
Old Aug 7, 2015 | 08:47 AM
ijimmy's Avatar
Lq9 has cathedral port heads , l92s and ls3s are rectangle port , they use different style intakes and throttle bodies
Old Aug 21, 2015 | 02:55 PM
thank you for the info!!
