Which hardware for this swap
Old Aug 4, 2015 | 04:23 PM
mjollnir's Avatar
Default Which hardware for this swap
Swapping a LQ4 and a T56 in the 1981 corvette, I'm having a few questions:
Is this a flywheel or flexplate and can I reuse it?
https://scontent-bru2-1.xx.fbcdn.net...a7&oe=563C595F
+ new ARP bolts
Getting this bearing:
http://www.gmpartsdirect.com/results...umber=12557583
Which Clutch do you recommend, I'd like something between OEM and track..
Old Aug 4, 2015 | 04:53 PM
mjollnir's Avatar
Bellhousing: http://www.summitracing.com/int/part...1001/overview/
Old Aug 4, 2015 | 06:07 PM
mjollnir's Avatar
http://lakewoodindustries.com/drivet...ine-plate.html
Any other plate that would be cheaper?
Old Aug 4, 2015 | 10:35 PM
Paul Bell's Avatar
That's MISTER MODERATOR
You'll do better here in the conversions section.
https://ls1tech.com/forums/generatio...g-threads.html
Old Aug 5, 2015 | 02:49 AM
mjollnir's Avatar
Of course, thanks Paul
Old Aug 5, 2015 | 10:29 PM
Project GatTagO's Avatar
The bearing that you have a link to is wrong. You need the small diameter bearing that goes deeper into the crank. I highly recommend the Luk Gold clutch kit:
Amazon.com: LuK 04-905 Clutch Set: Automotive Amazon.com: LuK 04-905 Clutch Set: Automotive
It's the same as an LS7 and comes with the flywheel, pilot bearing, flywheel bolts, pressure plate and disk. Even includes a new bearing but not the hydraulic part of the slave. I have this in my 1967 Cougar with a F-body t56 behind it. Works great with the F-body slave.
Why do you need the block plate?
Andrew
Old Aug 6, 2015 | 02:27 PM
mjollnir's Avatar
I thought the block plate was mandatory. Will not buy it then
Hmm that's a good price on the LUK.
Here is more info on my T56:
It's from a 1998 Camaro/Firebird. 26 input splines, 27 output
450 torque rating
Outer Diameter of the input splines: 1.5"
Outer diameter of the input "rod/shaft": 0.6"
That shaf protrudes a bit from the bellhousing
https://en.wikipedia.org/wiki/Borg-W...6_transmission
Will the LUK kit fit?
Old Aug 7, 2015 | 07:16 PM
Yes Sir!
Andrew
Old Aug 7, 2015 | 07:50 PM
mjollnir's Avatar
Yes Sir!
Andrew
Gteat ill order this week-end ! Thanks man
Check my project page ill post on it
