7.5 carrier please help
Old Aug 14, 2015 | 10:04 AM
GreazyDaMonsta's Avatar
Default 7.5 carrier please help
Can i put a posi carrier out of a up to a 92 s10 into my 79 monte carlo 7.5 rearend. If not which one can i use or what should i use. I know that there is something i can use without dumping alot of money in something ive never done.
Old Aug 14, 2015 | 02:40 PM
Ttt help
Old Aug 14, 2015 | 04:34 PM
aknovaman's Avatar
Why not run a 8.8 Ford Explorer in it. You won't break it and re drilling to chevy bolt pattern is easy.
Old Aug 14, 2015 | 08:53 PM
How is that
Old Aug 14, 2015 | 09:00 PM
jmd's Avatar
jmd
The axle splines (26 or 28) have to match.
The gears (2 or 3 series) have to match the carrier series.
If the 92 S10 is a gov-lock, skip it and get a real posi.
Old Aug 14, 2015 | 09:25 PM
What would be a real posi? I'm Ballin on a budget.
Old Aug 15, 2015 | 04:07 AM
tfi racing's Avatar
Just weld it up then,you will just break whatever Vega 7.5" stuff you will scrounge up.
There are a lot of variations in axle splines,pinion bearings,posi units,2,3,4 series carriers.Its just too much of a crap shoot to pin point exactly where to look,you will just have to pull some units and see what matches up with your housing.
Old Aug 15, 2015 | 12:55 PM
So up to 88 trans am camaro and s10 s15 would work if it has a posi?
Old Aug 15, 2015 | 07:26 PM
jmd's Avatar
jmd
26 to 28 spline axle changeover wasn't a definite year; S10s got 26 into the early 90s. Some V6 f-bodies got them later than 88 too.
An Eaton is a quality "posi" available in 26 spline.
The stock Auburns with cone frictions are usually unrebuildable when worn out.
If you don't know what you're talking about, don't bother providing misinformation. And take racing out of your username while you're at it.
Old Aug 16, 2015 | 06:34 AM
Are there any gm vehicles that I can get that out of or do I have to buy new?
Old Aug 16, 2015 | 01:16 PM
You guys fn rock
Old Aug 18, 2015 | 06:57 AM
Default new question
Since the 98 up camaro has a 7.5 posi carrier. Can I take carrier out with 28 spline put it on my rearend and buy new 28 spl axles?
