Clutch Problems Need Some Help
My money is on the MC or the slave. If it was working before without a shim, why would it all of a sudden need a shim? The LS7 clutch doesn't need a lot of travel to disengage.
Andrew
If the spring that holds the throwout bearing in contact failed, would that require excessive stroke of the slave to engage the bearing?
Silly me...
I've never use a stock MC in a swap, but have used the Wilwood MC in several. In my opinion the slaves are not nearly as problematic as a lot of people insist, but I think the stock style MC is not great.
Andrew
I just bled my tick master and it did something similar. I bled the hell out of it, then bled the 'top' portion of the travel and it works perfectly.
I'd also recommend getting a bleed screw with a check valve built into it (speed bleeder). Dorman and Russell makes them, then you don't need a buddy.
Read Post #6...
https://ls1tech.com/forums/manual-tr...-properly.html
Andrew
Next I took measurements to see if I needed a shim and got about 1/4" free play with the slave. Since all the numbers out there said that was too large I added .163 of shim to get about .087" of free play. Then we put the trans back in to try again. I temporarily installed the driveshaft into the trans so I could see if I could spin the output shaft of the trans. In neutral I could spin the driveshaft. WIth the trans in 1st gear and clutch not engaged I could not spin it (expected). Then in 1st gear with the clutch engaged I still couldn't spin it.
WTF is going on?????? I know the slave is engaging the clutch and pressing on the fingers and should be disengaging it. Is there a way for the clutch itself to fail which would not allow it to release the clutch?
Also, we got a hold of a scope and we were able to watch the slave cylinder push against the pressure plate fingers, so it looks like it has to be the pressure plate.
I put everything back together, without the screw, and I reduced my shim pack to .050" and when my friend pressed the clutch pedal with the trans in gear, the driveshaft spun easily. In fact with the shim I put in, the clutch release is closer to mid travel as opposed to right off the floor as it was before. I realize I may have a problem with slippage when the clutch gets near end of life, but as few miles as I put on this car, that will be 10 yrs down the road.
Are you kidding here? A screw? Where did that come from?
Don't worry about the clutch release down the road. The LS7 clutch has a self adjusting pressure plate that compensates for clutch wear (I actually thought this mechanism was somehow going bad on you...).
I am glad you found the issue!!!
Andrew
