Clutch Problems Need Some Help
I took the car out with my wife on Saturday afternoon and we stopped at a place for a beer. The car behaved totally normal on the way out. When we got back in the car to go home I suddenly could not get the car in gear. With the car shut off I could put it in gear no problem. I ended up starting the car in gear with the clutch depressed and the car would roll slightly and start and then I would try to shift without the clutch. About 2 minutes into the ride, the clutch started operating again although it felt like it was barely disengaging. The clutch worked normally for the rest of the 10 minute ride home.
The next day I inspected the whole system and saw no leaks and the level in the reservoir hadn't moved. I then started the car and the clutch acted normal. Figuring it couldn't hurt to bleed the clutch, I gathered the tools needed and planned to go over my buddys house. When I jumped back in the car again the clutch wouldn't disengage again. My buddy came over to my house and we bled the clutch in my driveway, but nothing changed.
Since the clutch master is the one from the donor car, I assumed it must have failed internally so I ordered a new one and started removing the old one. This is where I got confused. I disconnected the line going to the slave. As most people know this is a quick disconnect which locks the fluid in the line. Well if the clutch master had failed internally, you would think that you would now be able to depress the clutch pedal, but I couldn't it was solid as a rock. So now I don't know if replacing the master will solve my problem. I need some ideas.
What brand slave is in the car? I have seen reports of people having issues with anything other than GM slaves. The one that I have is branded as Luk, and it works fine.
No leaks anywhere?
Andrew
I think there are a few companies that sell a firewall mount kit for 1st gens that use the Wilwood (grilling style, which is what I am using) MC. This style of MC has 1.4" of travel and is better suited for swap applications.
On my 1970 GTO I am using the same MC, with a Kiesler mount, and a LS7 clutch, without any issues.
What's odd in your case is that it was working fine, but then it wasn't...I don't have a good answer for that.
Andrew
I know why did it stop working????
I read on the manual trans forum where someone had a problem with the input shaft not being greased properly and spinning with the crankshaft. I wonder if my pilot bearing could have failed.
