lsx in a XLR
Old Nov 20, 2015 | 02:47 PM
DavidBoren's Avatar
I knew it used the 'vette suspension, but didn't know it had the torque tube and rear mounted tranny. Good to know that it's longer, actually, given I want to use the rear mount transmission in a luxury sedan for better weight distribution... But the 'vette stuff is too short by a little bit and would require moving the engine and firewall too far back to leave legroom or room for pedals. So if it's just a few inches longer, it might allow the firewall to just be "massaged" with a hammer, rather than moving the whole firewall back.
Your car is F'ing awesome, by the way, sir.
Old Nov 26, 2015 | 10:49 PM
RonSSNova's Avatar
Even though I drive a C5, these XLR's always catch my eye.
So I want a red 04 with black interior......
Would like to poke around one of these. Read the tune.
Although the Northstar is cool, an LS1 or ??? Would make a ton more hp.
If, maybe a big If, the PCM was an 04 PO1, the swap could be pretty easy.
Very intriguing.
Ron
Old Nov 27, 2015 | 09:21 AM
Ls3xlr's Avatar
The biggest issue is the ecm program I still haven't got that all figured out yet
Old Nov 27, 2015 | 02:33 PM
RonSSNova's Avatar
I looked at the tune for an 07 in the HP Tuners repository.
There wasn't one avail for an 04.
I'm a tuner. With an electronics background. Stool sounds like a fun challenge.
Good luck! I get to Palm Springs from time to time. My dad lives there.
Old Nov 27, 2015 | 09:29 PM
RonSSNova's Avatar
Hmmm. I don't know but I can ask.
My guess is that the BCM needs to play nice with the ECM and when you told the ECM it was a diff vin, it wouldn't crank.
I'll see if I can find the two files.
Well,I can find the 09 CTS-V file, but not a supercharged 07 XLR-V file.
At any rate, not really very similar.
Old Nov 28, 2015 | 10:03 AM
RonSSNova's Avatar
I figured you did your homework on this. The CTSv file makes sense as it is also a supercharged engine.
Corvettes are also a Y body, so I think that is totally worth a shot.
What's another $100 right?
Are you using the new Beta HPT or the old version? The new allows segment swaps although I've not played with that at all.
Old Nov 28, 2015 | 01:14 PM
Ls3xlr's Avatar
The question is does it support engine segs
I don't have hpt yet either a friend of mine is the tuner at precision automotive
And we are using his stuff but I do want a copy for my self...
Also am I correct that hpt does not support full reflash to change programs?
Old Nov 28, 2015 | 05:43 PM
RonSSNova's Avatar
If the ECU is compatible with the program, HPT will do a full flash.
But you have to use 2 credits to license the program you wish to install.
Have you visited the HP Tuners forums yet?
http://www.hptuners.com/forum/
Old Nov 28, 2015 | 07:40 PM
Ls3xlr's Avatar
I've look at them a bit but I feel I've just scratched the surface....
I hoping to have my own copy of htp soon
So I can look around a bit more the info seems to be limited if the your not an owner of the program... but the forms seem promising
Old Nov 29, 2015 | 11:54 AM
RonSSNova's Avatar
Since it runs now, and everything works, what are the issues?
As far as swapping segments, you can only do that within the same operating system. And the XLR operating system appears to be unique from what I can tell.
If, writing a C6 operating system into your PCM works, you would be able to then convert it to a 2 bar speed density tune and eliminate the MAF (if you are running one) and be able to handle boost nicely.
Lots of iff's though.
Old Nov 29, 2015 | 07:59 PM
Ls3xlr's Avatar
What about the Saturn sky ls swaps
What program are they using kinda the same thing but they are going from a 4 cylinder to a V8 wtf....
Old Nov 30, 2015 | 12:03 AM
  #32
RonSSNova's Avatar
4 cam sensors for the variable timing.
I see a bunch of different Cam DTC's. So if you set 2, 3 & 4 to no error reported, it won't start huh?
Is the N* crank reluctor 58 tooth just like the LS3?
I looked up the Sky ECU. It's E69. I don't think the ecotec had variable cam timing? At any rate, those are pretty simple cars compared to the XLR. Might not have nearly as many do-dads to control.
I'd guess a custom harness and ECU were used.
Didn't GM build a V8 just for fun? I remember seeing it in the various magazines.
Old Nov 30, 2015 | 02:54 AM
  #33
Ls3xlr's Avatar
Yes is a 58x motor
I wish I had the file and a log to show you I'll see if I can get it here I a day or two from my guy
I thought the sky's were e37 someone has to know the secret and be willing to share
Basically I wanna trick it into setting corealation codes for the crank and cam and the those off I think is the route I'm going... I did join the hpt forum and am looking through it I'd like to chat will bill from hot he seems pretty smart ......
Old Nov 30, 2015 | 09:56 AM
  #34
RonSSNova's Avatar
Put up a post in the PCM diagnostics and Tuning section here in LS1 Tech.
There are some pretty sharp folks here who may be able to help.
HPT forum is very hit and miss
Old Nov 30, 2015 | 10:24 PM
  #35
Ls3xlr's Avatar
Sorry I took most of our conversation down I don't wanna share my secrets
With the whole world... is there any way to pm of this fourm?
Old Dec 1, 2015 | 12:25 AM
  #36
RonSSNova's Avatar
I sent you a private message.
Should appear in the upper right when you log in with a PC.
If on the phone, just click on my name, it will let you send me a message
Old Oct 27, 2016 | 07:55 AM
  #37
Ron Ron's Avatar
Default ls swap in xlr
i was tryin to buy a xlr and do the Same have u worked out all kinks and problems if so how much would u charge to do one for me? Since u not giving out ur secerts I understand but I don't wanna buy one unless I can add a better engine u can email if u like personally
Old Oct 28, 2016 | 05:23 PM
  #38
Ls3xlr's Avatar
Default Xlr swap
my name is kyle give me a ring and we can talk about it
760 333 3067
where r u?
Old Mar 17, 2018 | 05:43 PM
  #39
Ron Ron's Avatar
Could u email me the info for the swap? Kghee79@gmail.com
Old Apr 19, 2019 | 09:39 AM
  #40
lasstss's Avatar
Im thinking of doing this. I have done other conversions. This post is quite old. Do yo still have the car?
Marty
