electric power steering pump.
Old Sep 16, 2015 | 12:09 PM
DavidBoren's Avatar
The post and question are not about upgrading performance. Nobody has to guess or assume anything about what it is for. The OP clearly states that the engine he currently has, an L83, does not have a power steering pump. He is looking for an easy retrofit solution.
I can see why using an oem electric power steering pump that can be found in the junkyard would be more appealing than buying/mounting brackets, a belt driven power steering pump, and getting a new belt of the proper length.
Just mounting an electric power steering pump any place it will fit and plugging in some wires is an attractive alternative.
And if he isn't racing his full size pickup truck through the cones every Saturday morning, then an electric pump will probably be just fine.
Old Sep 16, 2015 | 12:30 PM
goodwrenchbutch's Avatar
I talked to Chevrolet Performance Parts while I was on the HRPT and they said the will have a pump/ bracket out for this at the end of the year
Old Sep 16, 2015 | 12:41 PM
stevieturbo's Avatar
I agree, the electro hydraulic can work for many, but they are not a good performance solution if that's what the application requires.
Old Sep 16, 2015 | 05:00 PM
frige's Avatar
I would love to use a belt driven pump. Its just at this point no one makes a bracket for the l83. And yes I could probably cobble together a bracket but I am not a design engineer type of person and it would look like crap and probably break before long. I am not incompetent by any means I have been racing for a long time and currently my little Luv truck which is totally garage built will run a 5.0 1/8th with a little sbc. If you dont believe me ask James Love from OK. Here is a vid of the Luv. Kinda wounded it on that pass. Lol
But anyway I didnt want to start a big deal I just want to build a really cool street truck and I am trying to solve my problems before I start setting the engine.
Old Feb 7, 2016 | 12:11 PM
unnatrl's Avatar
For what its worth, I got my electric p/s setup functioning. It's in a 5 series BMW using the Volvo V40 pump. Granted, it's not quite as heavy as the OP's vehicle. I don't notice any abnormal qualities/ flaws so far (the car is still in the "shakedown" phase and has only been driven around the block). The steering was the one thing I had no worries about after the test drive. It works really well.
Old Feb 7, 2016 | 01:36 PM
EFIHARNESS's Avatar
look at the electric steering from the equinox or hhr. The unit goes between the steering wheel and the rack. we use them on a lot of cars where you don't want the fluid and or want adjustable torque. Cheap under $200
Old Feb 8, 2016 | 07:51 AM
veltboy618's Avatar
Also check the Saturn VUE electronic power steering unit. They are adjustable & can be found in the yards for pretty cheap also. They go between the steering wheel & the steering rack too.
Here's a video on it
Old Feb 8, 2016 | 08:01 AM
Obviously that was convenient for the guy in the video, but that's one hell of an angle for the UJ to run at
Other thing to note about a proper hydraulic PAS rack, vs an assisted column on an otherwise old mechanical non assisted rack. Often the proper hydraulic rack is far fewer turns lock to lock which is good for anything that gets driven hard
Old Feb 8, 2016 | 04:03 PM
jimmyg's Avatar
X2 Saturn vue
Old Jul 26, 2017 | 12:45 PM
novablue454's Avatar
Bumping this old thread because I am looking for info on retrofitting the volvo pump in to my drift car. I recently purchased an RX7 with the volvo pump and am confused by all these "no good with quick inputs" statements. It works awesome in the RX with 65ish degrees of angle and I can't think of anything that takes more steering inputs then drifting. Also, almost the entire FD field is using electric steering of some sort.
Old Jul 26, 2017 | 01:31 PM
Except with drifting, most of the fast steering is achieved with the drivers letting go of the steering wheel and allowing the suspension geometry etc to actually change direction. Less so the driver actually making steering changes.
If you have seen people using the system you want for the type of usage you want, then that should prove they are viable.
But I know people for road course or circuit racing on sticky tyres where such systems have not worked well at all.
Old Jul 26, 2017 | 02:20 PM
  #32
ah that makes sense. Yeah, a lot of it beyond the initiation point is controlled with throttle inputs and such rather then actual steering input. I guess I was misinterpreting steering input as steering movement.
thanks for clearing that up.
