electric power steering pump.
Old Sep 10, 2015 | 08:07 AM
frige's Avatar
Default electric power steering pump.
I have been searching the web looking for a solution for my L83 engines lack of a power steering pump. I found a lot of compact cars have them but I am not sure they will handle the 89 silverado steering box. I found this one but man is it pricey.
http://www.evsource.com/tls_steering.php
Anyone have a idea of a oem pump that would work?
Old Sep 10, 2015 | 09:37 AM
Pop N Wood's Avatar
Ouch. I would go the salvage yard route.
Seems like Yota MR2 pumps were one of the earliest electric PS pumps and as such have been modified into all sorts of vehicles. A Google search will show you all the things they have been backfit into. But lots of car manufactures are using them now. My Kia Forte and Mazda 3 both have electric pumps.
Guess I would do an internet search on the types of new cars with electric PS pumps than see if one could be back fit.
I considered getting an electric pump just for hydraboost brakes. That would need minimal capacity.
Old Sep 10, 2015 | 10:21 AM
DavidBoren's Avatar
I was going to mention the mister2 pump, but I'm not entirely sure it would last long in a heavy truck application.
TRW and Nexteer both make heavy duty electric power steering pumps, but I can only imagine what they cost.
You can look at unisteer and/or ezpowersteering, but once again, I'm not sure how well the smaller units will do in a truck.
Old Sep 10, 2015 | 03:25 PM
frige's Avatar
I found a few that look promising. The only thing is I see some of the pumps use a computer to control pressure. I wonder if they can be set to run wide open or if they have to have the controller.
Old Sep 10, 2015 | 03:28 PM
DavidBoren's Avatar
You could probably find a spec sheet, or even test it with a voltmeter, maybe, to find out what voltage equates to what output pressure. Then just wire it up with the proper resistors to have it always at that voltage.
Old Sep 10, 2015 | 05:57 PM
1964SS's Avatar
Nobody makes an adapter for a type 2 pump on these yet? Have you tried street and performance? They may have an adapter.
Old Sep 10, 2015 | 06:35 PM
frige's Avatar
No I talked to James and they have not made one yet. He said they made one wiring harness so far but the customer hasnt ran it yet.
Old Sep 13, 2015 | 04:33 PM
unnatrl's Avatar
Look into the Volvo V40 electric pump. They are much easier to find. It's a brushless design (more reliable than the MR2). I'm working on installing one into my LS swapped BMW.
Another option is the Subaru XT6 pump. Like the MR2 pump, they are scarce and expensive. It may not work of you do find one.
You can cruise the the electric Vehicle conversion forums and find a wealth of knowledge on this stuff.
Old Sep 13, 2015 | 05:27 PM
Fierofly's Avatar
This is the one I used on my Porsche LS3 conversion, It's a Toyota MR2 pump came with a kit I bought from Renegade Hybrids. Its worked good so far 2000mi.
Old Sep 13, 2015 | 06:09 PM
stevieturbo's Avatar
As long as you dont need to steer fast, electric pumps usually work ok.
Some small French cars use electric, some small Mercedes cars, and the Toyotas mentioned.
But surely there is a mechanical pump you can bolt to the engine ?
Old Sep 14, 2015 | 04:42 PM
frige's Avatar
I do like the toyota pump but they are hard to find in good shape as the cars are so old. This Volvo pump looks good.
http://www.ebay.com/itm/Volvo-S40-V50-C30-Electric-Power-Steering-Pump-05-08-/371414955611?hash=item567a0e765b&vxp=mtrIt only has 2 control wires so maybe I could figure out how to slow it down a bit. Anyone know where I could find the specs on these pumps?
Old Sep 14, 2015 | 06:59 PM
unnatrl's Avatar
This also requires a keyed 12v to turn the pump on. In my research, the pump is supposed to run at ~75% of its Maximum power/ pressure when wired like this (no computer/ CAN bus integration). The price in the auction listed is very reasonable. I had to buy the harness from Volvo (54.00) as mine didn't have it.
See this link for more info-
http://www.diyelectriccar.com/forums...7/topics/44828
Old Sep 15, 2015 | 09:59 AM
DavidBoren's Avatar
That Volvo pump looks nice. I like the brushless motor design. But I still don't know if it's up to the task of steering a truck.
Old Sep 15, 2015 | 12:01 PM
Most of the pumps will cope fine with slow movements, so normal road driving shouldnt be a problem.
I wouldnt trust an electric pump on anything that needed fast steering inputs.
Old Sep 15, 2015 | 08:14 PM
DavidBoren's Avatar
Doesn't the c7 'vette have electric power steering?
The next question(s) is/are:
Is it reliable?
And is it obtainable to us mere mortals?
Because the c7 is kind of meant for quick steering, and the like.
Old Sep 15, 2015 | 08:19 PM
DavidBoren's Avatar
KRC, among others, make some slick power steering pumps that mount in various locations, such as off the front of the heads.
This may be a viable option if you cannot find an electric power steering pump that fits your needs.
Old Sep 15, 2015 | 09:06 PM
unnatrl's Avatar
Many of electric p/s systems provide assist at slow speeds and gradually decrease the assist as the speed of the car increases. I don't think the amount of assist available at a higher speed is going to make the car feel much different in a quick maneuver. If anything, it may make the steering overly sensitive.
Old Sep 16, 2015 | 04:49 AM
You miss the point, the electro-hydraulic setups simply dont have the power to respond fast enough at times.
I know several people who swapped from engine hydraulic to electro hydraulic on their race cars...for **** knows what reason. Almost all of them changed back after some time because the electric pumps simply couldnt cope.
As for the reference to the C7...I'm pretty sure it doesnt use a Volvo or any other mundane passenger car electro hydraulic setup as an afterthought
It uses a dedicated electric assisted rack designed for the job in hand, so it's a nonsense comparison.
The other option is the after fitment of electric motor assistance to the column itself that some cars use.
But again, if you want a foolproof tried and tested setup that will always have adequate assistance, just bolt a proper pump to the engine. That always works.
The other afterthoughts usually work, or work ok, but not always. Again just depends on the expectations and usage.
Old Sep 16, 2015 | 05:22 AM
Pop N Wood's Avatar
By the same logic why not just stay with the stock engine?
I think you are hanging out on the wrong site, definitely wrong forum.
Mazda 3 pump
http://www.ebay.com/itm/04-05-Mazda-...-/321752458156
Old Sep 16, 2015 | 05:32 AM
Mazda 3 pump
What a dumb reply.
The comparison you're trying to make is instead of fitting a good pump, you want to fit potentially a lesser quality and able pump.
So by your logic instead of the stock engine, you want a shitty 1.6 n/a diesel engine.
Just because electro hydraulic pumps are available, does not mean they are better than a mechanical pump...and in absolutely every instance I've seen where people have used them, they are less capable than the mechanical pump.
I've already stated in very clear terms the shortcomings of electro hydraulic setups. You can choose to ignore them if you choose, or maybe as stated the vehicle will never require fast steering inputs and such a setup will work fine.
And really...if you can manage an engine swap and cant manage to bolt a mechanical PAS pump to the engine...something is badly wrong. It isnt rocket science by any means and virtually any mechanical pump will be better than the electrohydraulic versions.....again, if your car is used at a level where it would even matter. Yours may well not be.
But I'd presume the forum is for upgrading performance...so do bare that in mind..
