superskater's Foxbody 408 LQ9/S480/T56 Build Thread
Old 10-16-2015, 01:39 PM
BobtailedSnail's Avatar
Awesome work Ant. Can't wait to see this project done and hit the goals you intend. hopefully I'll be starting my C20 thread here soon.....once my speed6 is done.
Old 10-19-2015, 05:28 AM
superskaterxes's Avatar
Originally Posted by Steven32
how low does it hang down?
pict as requested.
it hangs down a little lower then i realized but i think i am going to leave it for now.
I also got my bracket all mocked up and everything fits great! i have plenty of clearance between the belt and TB and it looks like everything lines up correctly. I just ordered the rest of my exhaust piping so i should be able to start mocking up the manifolds shortly!
Old 10-19-2015, 07:30 AM
booboo37's Avatar
I wouldn't drive the car with that truck oil pan and your car don't look like its sitting on the ground all the way ??.Did you try the f-body pan ?. if this is the 2nd design teamz k-member then the f-body pan should fit ..but that k-member are not all the same from front to back so theres a chance that it won't fit...Did you make sure that the motor and trans sit at the right angle ?? should be lower in the back -1 ...-3......heres my AJE k-member and AJE trans cross member.. and f-body pan.
Old 10-19-2015, 01:01 PM
I havent tried any other pan's yet but im pretty sure the f-body pan will hit the k-member due to the sump being too far forward. I still need to pull the motor for final final assembly (only in there for mockup right now) so ill make a decision then. Thanks for the heads up.
Old 10-19-2015, 05:54 PM
booboo37's Avatar
No problem and when Dave at Teamz mocked up the 2nd design LS fox body k-member he used a th350 trans and f-body LS1 oil pan..,,..this is why a 4l60, 4l80 trans don't fit......those trans are taller........Dave was ask to put a note on his web site and never did..
Looking back at your pics u need to move the motor towards the fire wall....if a f-body pan don't fit then your motor mounts could be on the wrong side...but the k-members seem to be different .....
Heres some info
http://www.yellowbullet.com/forum/sh....php?t=1387322
Old 10-19-2015, 06:05 PM
booboo37's Avatar
This guy has a Magnum t56 with the teamz ls fox k-member..
https://ls1tech.com/forums/conversio...ang-cobra.html
Old 10-21-2015, 05:35 AM
i took another look at this yesterday and i cant move the motor any farther back or else the shifter wont line up with the console. I dont really want to chop up the console any to make an oil pan fit (i do have a welder and the ability to modify the pan) so i might go that route.
Does anyone see any harm in just shortening the truck pan?
Old 10-21-2015, 12:53 PM
Teddy-2000RS's Avatar
There's a swap kit that uses cut and shotened truck pan with good success. The only thing i saw added was the oil return bung and a trap door for hard acceleration to keep the oil from starving the pick up.
Old 10-21-2015, 03:47 PM
booboo37's Avatar
You can see how close i I'm to the fire wall with my AJE k-member.....not sure if thats a good idea or not about the oil pan..i think there was another guy that got stuck and cut the truck pan tho..........any questions let me know..
Old 10-21-2015, 04:12 PM
booboo37's Avatar
This guy was pissed and has the new teamz k member and he figure out he had the mounts on the wrong side but u can see he could not move the motor back cause the 4l60 trans was hitting the tunnel so he ended up making short motor mounts like the other guy had to do..
Old 10-22-2015, 10:28 PM
truckdoug's Avatar
Originally Posted by superskaterxes
which ones are you referring to? theres the ones on the outter tie rods and on the LCA's
tie rod ends
Old 12-03-2015, 08:35 PM
  #32
so i havent updated in a while as i have been away for work lately. I started fabbing up the turbo kit and i think its coming along nicely! need to finish the DP and then start on the exhaust.
Old 12-16-2015, 02:10 PM
  #33
finished the DP and most of the midpipe. Parts just came in to fill the gap in the middle so once i get some more free time i can finish this up!
Old 02-15-2016, 03:04 PM
  #34
FrossB's Avatar
This project still going? Id love to see progress on it
Old 02-15-2016, 07:50 PM
  #35
slowly but surely lol
ive been away for work the last few months so i havent had a good amount of time to really get back into things. Plus im waiting for this to get installed =D
http://www.garagejournal.com/forum/s...&postcount=718
hopefully sometime at the end of the month or early march i will be back in it. I dont really have that much left to do and i have 90% of the parts i need for completion.
Old 02-15-2016, 09:20 PM
  #36
lilpanther's Avatar
Great build. Just a note though, you have your engine mount's on backwards, That's why your engine is sitting as far forward as it is and why the sump on the truck man is that close to the kmember.
Old 02-15-2016, 09:22 PM
  #37
they are that direction for a reason lol shifter wont line up with trans hole otherwise.
Old 02-16-2016, 09:56 AM
  #38
FrossB's Avatar
Heck yea! I wish I had a lift lol I HATE rolling around on the concrete smacking my forehead on everything.
I'm excited to see this thing get finished!
Old 02-16-2016, 09:47 PM
  #39
jimmyg's Avatar
You could try the holley 302-2 pan . Also I love your bracket . It is very similar to one from ls brackets.com I'm going to use on my whipple build. The only thing I would do different is install the idler on the water pump bosses for better belt wrap on the water pump. I love ls fox bodies .that thing is going to move!
Old 02-18-2016, 08:13 AM
  #40
thanks!
i am going to just trim the truck pan so it doesn't hang down so low. Should be a relatively simple task 0_o
Quick Reply: superskater's Foxbody 408 LQ9/S480/T56 Build Thread
